[rtems commit] PR2040: libblock: Track number of erased blocks
Joel Sherrill
joel at rtems.org
Thu Mar 29 09:14:31 CDT 2012
Module: rtems
Branch: master
Commit: 65b6aebd22993367015028c7743c26e64d1ea9b6
Changeset: http://git.rtems.org/rtems/commit/?id=65b6aebd22993367015028c7743c26e64d1ea9b6
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date: Tue Mar 13 14:52:57 2012 +0100
cpukit/libblock/src/flashdisk.c | 9 ++++++++-
1 files changed, 8 insertions(+), 1 deletions(-)
diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
index 8a478cf..0768e1c 100644
--- a/cpukit/libblock/src/flashdisk.c
+++ b/cpukit/libblock/src/flashdisk.c
@@ -252,6 +252,7 @@ typedef struct rtems_flashdisk
mappings. */
uint32_t block_count; /**< The number of avail. blocks. */
uint32_t unavail_blocks; /**< The number of unavail blocks. */
+ uint32_t erased_blocks; /**< The number of erased blocks. */
rtems_fdisk_device_ctl* devices; /**< The flash devices for this
disk. */
@@ -968,6 +969,7 @@ rtems_fdisk_seg_write_page (rtems_flashdisk* fd,
if (ret)
return ret;
+ --fd->erased_blocks;
return rtems_fdisk_seg_write (fd, sc,
page * fd->block_size, buffer, fd->block_size);
@@ -1145,6 +1147,7 @@ rtems_fdisk_erase_segment (rtems_flashdisk* fd, rtems_fdisk_segment_ctl* sc)
return ret;
+ fd->erased_blocks += sc->pages;
sc->erased++;
memset (sc->page_descriptors, 0xff, sc->pages_desc * fd->block_size);
@@ -1608,7 +1611,11 @@ rtems_fdisk_recover_block_mappings (rtems_flashdisk* fd)
ret = rtems_fdisk_seg_blank_check_page (fd, sc,
page + sc->pages_desc);
- if (ret)
+ if (ret == 0)
+ ++fd->erased_blocks;
+ else
#if RTEMS_FDISK_TRACE
rtems_fdisk_warning (fd, "page not blank: %d-%d-%d",
More information about the rtems-vc
