[rtems-crossrpms commit] Remove.
Ralf Corsepius
ralf at rtems.org
Wed Mar 28 10:15:47 CDT 2012
Module: rtems-crossrpms
Branch: master
Commit: e7773a20aa7d54c31725eea3dc12c7fb2209e570
Changeset: http://git.rtems.org/rtems-crossrpms/commit/?id=e7773a20aa7d54c31725eea3dc12c7fb2209e570
Author: Ralf Corsépius <ralf.corsepius at rtems.org>
Date: Sat Mar 24 07:06:21 2012 +0100
Remove.
patches/gcc-4.7.0-rtems4.11-20120222.diff | 256 -----------------------------
1 files changed, 0 insertions(+), 256 deletions(-)
diff --git a/patches/gcc-4.7.0-rtems4.11-20120222.diff b/patches/gcc-4.7.0-rtems4.11-20120222.diff
deleted file mode 100644
index 19bcd24..0000000
--- a/patches/gcc-4.7.0-rtems4.11-20120222.diff
+++ /dev/null
@@ -1,256 +0,0 @@
-diff -Naur gcc-4.7.0.orig/gcc/ChangeLog.rtems gcc-4.7.0/gcc/ChangeLog.rtems
---- gcc-4.7.0.orig/gcc/ChangeLog.rtems 1970-01-01 01:00:00.000000000 +0100
-+++ gcc-4.7.0/gcc/ChangeLog.rtems 2012-03-23 18:59:02.399079172 +0100
-@@ -0,0 +1,45 @@
-+2011-10-28 Ralf Corsépius <ralf.corsepius at rtems.org>
-+ * config/avr/rtems.h: Remove __USE_INIT_FINI__.
-+2011-06-20 Ralf Corsépius <ralf.corsepius at rtems.org>
-+ * sparc/t-rtems: Reflect introduction of sparc/t-crtin.
-+2011-03-23 Joel Sherrill <joel.sherrill at oarcorp.com>
-+ * config.gcc (sparc-*-rtems*, sparc64-*-rtems*):
-+ Add sparc/t-rtems, crti.o crtn.o.
-+ * config/sparc/t-rtems: New.
-+2011-03-22 Ralf Corsépius <ralf.corsepius at rtems.org>
-+ * config.gcc (sparc64-rtems*): Remove sysv.h from tm_file.
-+2010-05-19 Joel Sherrill <joel.sherrill at oarcorp.com>
-+ * config.gcc (sparc64-*-rtems*): New target.
-+ * config/sparc/sp64-rtemself.h: New file.
-+2010-04-19 Ralf Corsépius <ralf.corsepius at rtems.org>
-+ * ginclude/stddef.h: Define _MACHINE_ANSI_H_ if _X86_64_ANSI_H_ is
-+ defined (Used by amd64-*-netbsdelf5.*).
-+2010-04-18 Ralf Corsépius <ralf.corsepius at rtems.org>
-+ * ginclude/stddef.h: Define _MACHINE_ANSI_H_ if _I386_ANSI_H_ is
-+ defined (Used by i386-*-netbsdelf5.*).
-+2009-11-04 Ralf Corsépius <ralf.corsepius at rtems.org>
-+ * config/m32c/rtems.h, config/m68k/rtemself.h,
-+ config/m68k/rtemself.h, config/sh/rtemself.h,
-+ config/sparc/rtemself.h: Undef WCHAR_TYPE_SIZE, WCHAR_TYPE.
-+ (Resets WCHAR_TYPE's to defaults. Prevents broken GCC tm_files
-+ to interfere and cause wchar_t/wint_t incompatibilities).
-+ Ralf Corsépius <ralf.corsepius at rtems.org>
-+ * config/mips/elf.h: Remove NO_IMPLICIT_EXTERN_C.
-diff -Naur gcc-4.7.0.orig/gcc/config/avr/rtems.h gcc-4.7.0/gcc/config/avr/rtems.h
---- gcc-4.7.0.orig/gcc/config/avr/rtems.h 2007-08-02 12:49:31.000000000 +0200
-+++ gcc-4.7.0/gcc/config/avr/rtems.h 2012-03-23 18:59:02.410079350 +0100
-@@ -23,6 +23,5 @@
- #define TARGET_OS_CPP_BUILTINS() \
- do { \
- builtin_define ("__rtems__"); \
-- builtin_define ("__USE_INIT_FINI__"); \
- builtin_assert ("system=rtems"); \
- } while (0)
-diff -Naur gcc-4.7.0.orig/gcc/config/avr/t-rtems gcc-4.7.0/gcc/config/avr/t-rtems
---- gcc-4.7.0.orig/gcc/config/avr/t-rtems 2004-11-23 04:44:03.000000000 +0100
-+++ gcc-4.7.0/gcc/config/avr/t-rtems 2012-03-23 18:59:02.410079350 +0100
-@@ -1,3 +1,4 @@
- # Multilibs for avr RTEMS targets.
--# ATM, this is just a stub
-+# RTEMS uses _exit from newlib
-+LIB1ASMFUNCS := $(filter-out _exit,$(LIB1ASMFUNCS))
-diff -Naur gcc-4.7.0.orig/gcc/config/h8300/h8300.h gcc-4.7.0/gcc/config/h8300/h8300.h
---- gcc-4.7.0.orig/gcc/config/h8300/h8300.h 2011-07-20 00:34:31.000000000 +0200
-+++ gcc-4.7.0/gcc/config/h8300/h8300.h 2012-03-23 18:59:02.410079350 +0100
-@@ -129,6 +129,7 @@
- #define INCOMING_FRAME_SP_OFFSET (POINTER_SIZE / 8)
- #define DWARF_CIE_DATA_ALIGNMENT 2
-+#define DWARF2_ADDR_SIZE 4
- /* Define this if addresses of constant functions
- shouldn't be put through pseudo regs where they can be cse'd.
-diff -Naur gcc-4.7.0.orig/gcc/config/m32c/rtems.h gcc-4.7.0/gcc/config/m32c/rtems.h
---- gcc-4.7.0.orig/gcc/config/m32c/rtems.h 2008-12-01 17:34:42.000000000 +0100
-+++ gcc-4.7.0/gcc/config/m32c/rtems.h 2012-03-23 18:59:02.425079593 +0100
-@@ -29,5 +29,9 @@
- while (0)
--/* Use the default */
-+/* Use the defaults */
- #undef LINK_GCC_C_SEQUENCE_SPEC
-+#undef WCHAR_TYPE
-+#undef WCHAR_TYPE_SIZE
-diff -Naur gcc-4.7.0.orig/gcc/config/m68k/rtemself.h gcc-4.7.0/gcc/config/m68k/rtemself.h
---- gcc-4.7.0.orig/gcc/config/m68k/rtemself.h 2007-08-02 12:49:31.000000000 +0200
-+++ gcc-4.7.0/gcc/config/m68k/rtemself.h 2012-03-23 18:59:02.425079593 +0100
-@@ -31,3 +31,8 @@
- while (0)
-+#undef WCHAR_TYPE
-diff -Naur gcc-4.7.0.orig/gcc/config/mips/elf.h gcc-4.7.0/gcc/config/mips/elf.h
---- gcc-4.7.0.orig/gcc/config/mips/elf.h 2010-11-21 01:54:14.000000000 +0100
-+++ gcc-4.7.0/gcc/config/mips/elf.h 2012-03-23 18:59:02.425079593 +0100
-@@ -47,5 +47,3 @@
- #undef ENDFILE_SPEC
- #define ENDFILE_SPEC "crtend%O%s crtn%O%s"
--#define NO_IMPLICIT_EXTERN_C 1
-diff -Naur gcc-4.7.0.orig/gcc/config/rs6000/rtems.h gcc-4.7.0/gcc/config/rs6000/rtems.h
---- gcc-4.7.0.orig/gcc/config/rs6000/rtems.h 2011-12-06 23:49:57.000000000 +0100
-+++ gcc-4.7.0/gcc/config/rs6000/rtems.h 2012-03-23 18:59:02.425079593 +0100
-@@ -69,3 +69,7 @@
- rs6000_spe_abi = 1; \
- } while(0)
-+#undef WCHAR_TYPE
-diff -Naur gcc-4.7.0.orig/gcc/config/sh/rtemself.h gcc-4.7.0/gcc/config/sh/rtemself.h
---- gcc-4.7.0.orig/gcc/config/sh/rtemself.h 2007-08-02 12:49:31.000000000 +0200
-+++ gcc-4.7.0/gcc/config/sh/rtemself.h 2012-03-23 18:59:02.426079609 +0100
-@@ -24,3 +24,8 @@
- builtin_define( "__rtems__" ); \
- builtin_assert( "system=rtems" ); \
- } while (0)
-+#undef WCHAR_TYPE
-diff -Naur gcc-4.7.0.orig/gcc/config/sparc/rtemself.h gcc-4.7.0/gcc/config/sparc/rtemself.h
---- gcc-4.7.0.orig/gcc/config/sparc/rtemself.h 2007-08-02 12:49:31.000000000 +0200
-+++ gcc-4.7.0/gcc/config/sparc/rtemself.h 2012-03-23 18:59:02.426079609 +0100
-@@ -29,5 +29,9 @@
- while (0)
-+#undef WCHAR_TYPE
-diff -Naur gcc-4.7.0.orig/gcc/config/sparc/sp64-rtemself.h gcc-4.7.0/gcc/config/sparc/sp64-rtemself.h
---- gcc-4.7.0.orig/gcc/config/sparc/sp64-rtemself.h 1970-01-01 01:00:00.000000000 +0100
-+++ gcc-4.7.0/gcc/config/sparc/sp64-rtemself.h 2012-03-23 18:59:02.426079609 +0100
-@@ -0,0 +1,37 @@
-+/* Definitions for rtems targeting a SPARC64 using ELF.
-+ Copyright (C) 2010 Free Software Foundation, Inc.
-+ Contributed by Joel Sherrill (joel at OARcorp.com).
-+This file is part of GCC.
-+GCC is free software; you can redistribute it and/or modify
-+it under the terms of the GNU General Public License as published by
-+the Free Software Foundation; either version 3, or (at your option)
-+any later version.
-+GCC is distributed in the hope that it will be useful,
-+but WITHOUT ANY WARRANTY; without even the implied warranty of
-+MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-+GNU General Public License for more details.
-+You should have received a copy of the GNU General Public License
-+along with GCC; see the file COPYING3. If not see
-+<http://www.gnu.org/licenses/>. */
-+/* Target OS builtins. */
-+#undef TARGET_OS_CPP_BUILTINS
-+#define TARGET_OS_CPP_BUILTINS() \
-+ do \
-+ builtin_define ("__rtems__"); \
-+ builtin_define ("__USE_INIT_FINI__"); \
-+ builtin_assert ("system=rtems"); \
-+ while (0)
-+/* Use the default */
-+#undef LINK_GCC_C_SEQUENCE_SPEC
-+/* we are not svr4 */
-+#undef CPP_SUBTARGET_SPEC
-+#define CPP_SUBTARGET_SPEC ""
-diff -Naur gcc-4.7.0.orig/gcc/config/sparc/t-rtems gcc-4.7.0/gcc/config/sparc/t-rtems
---- gcc-4.7.0.orig/gcc/config/sparc/t-rtems 1970-01-01 01:00:00.000000000 +0100
-+++ gcc-4.7.0/gcc/config/sparc/t-rtems 2012-03-23 18:59:02.426079609 +0100
-@@ -0,0 +1,18 @@
-+# Copyright (C) 2011 Free Software Foundation, Inc.
-+# This file is part of GCC.
-+# GCC is free software; you can redistribute it and/or modify
-+# it under the terms of the GNU General Public License as published by
-+# the Free Software Foundation; either version 3, or (at your option)
-+# any later version.
-+# GCC is distributed in the hope that it will be useful,
-+# but WITHOUT ANY WARRANTY; without even the implied warranty of
-+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-+# GNU General Public License for more details.
-+# You should have received a copy of the GNU General Public License
-+# along with GCC; see the file COPYING3. If not see
-+# <http://www.gnu.org/licenses/>.
-diff -Naur gcc-4.7.0.orig/gcc/config.gcc gcc-4.7.0/gcc/config.gcc
---- gcc-4.7.0.orig/gcc/config.gcc 2012-03-05 11:43:22.000000000 +0100
-+++ gcc-4.7.0/gcc/config.gcc 2012-03-23 18:59:02.409079334 +0100
-@@ -2380,7 +2380,8 @@
- sparc-*-rtems*)
- tm_file="${tm_file} dbxelf.h elfos.h sparc/sysv4.h sparc/sp-elf.h sparc/rtemself.h rtems.h newlib-stdint.h"
-- tmake_file="sparc/t-sparc sparc/t-elf t-rtems"
-+ tmake_file="sparc/t-sparc sparc/t-elf sparc/t-rtems t-rtems"
-+ extra_parts="crtbegin.o crtend.o"
- sparc-*-linux*)
- tm_file="${tm_file} dbxelf.h elfos.h sparc/sysv4.h gnu-user.h linux.h glibc-stdint.h sparc/tso.h"
-@@ -2433,8 +2434,9 @@
- sparc64-*-rtems*)
- tm_file="${tm_file} dbxelf.h elfos.h newlib-stdint.h sparc/sysv4.h sparc/sp64-elf.h sparc/rtemself.h rtems.h"
- extra_options="${extra_options}"
-- tmake_file="${tmake_file} sparc/t-sparc t-rtems"
-+ tmake_file="${tmake_file} sparc/t-crtin sparc/t-crtfm sparc/t-rtems t-rtems"
- sparc64-*-linux*)
- tm_file="sparc/biarch64.h ${tm_file} dbxelf.h elfos.h sparc/sysv4.h gnu-user.h linux.h glibc-stdint.h sparc/default-64.h sparc/linux64.h sparc/tso.h"
- extra_options="${extra_options} sparc/long-double-switch.opt"
-diff -Naur gcc-4.7.0.orig/gcc/ginclude/stddef.h gcc-4.7.0/gcc/ginclude/stddef.h
---- gcc-4.7.0.orig/gcc/ginclude/stddef.h 2012-02-12 02:06:04.000000000 +0100
-+++ gcc-4.7.0/gcc/ginclude/stddef.h 2012-03-23 18:59:02.427079625 +0100
-@@ -53,7 +53,13 @@
- one less case to deal with in the following. */
- #if defined (__BSD_NET2__) || defined (____386BSD____) || (defined (__FreeBSD__) && (__FreeBSD__ < 5)) || defined(__NetBSD__)
- #include <machine/ansi.h>
-+#if !defined(_MACHINE_ANSI_H_)
-+#if defined(_I386_ANSI_H_) || defined(_X86_64_ANSI_H_)
-+#define _MACHINE_ANSI_H_
- #endif
-+#endif
-+#endif
- /* On FreeBSD 5, machine/ansi.h does not exist anymore... */
- #if defined (__FreeBSD__) && (__FreeBSD__ >= 5)
- #include <sys/_types.h>
More information about the rtems-vc
