[rtems commit] PR2040: libblock: Flash disk documentation
Sebastian Huber
sebh at rtems.org
Wed Mar 14 05:48:58 CDT 2012
Module: rtems
Branch: 4.10
Commit: 1c47c470b304bbc6e15c64bdc95749920e94d67e
Changeset: http://git.rtems.org/rtems/commit/?id=1c47c470b304bbc6e15c64bdc95749920e94d67e
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date: Wed Mar 14 10:33:55 2012 +0100
cpukit/libblock/include/rtems/flashdisk.h | 151 +++++++++++++++++++++++-----
cpukit/libblock/src/flashdisk.c | 81 +---------------
2 files changed, 127 insertions(+), 105 deletions(-)
diff --git a/cpukit/libblock/include/rtems/flashdisk.h b/cpukit/libblock/include/rtems/flashdisk.h
index c24b9b0..3f8b11b 100644
--- a/cpukit/libblock/include/rtems/flashdisk.h
+++ b/cpukit/libblock/include/rtems/flashdisk.h
@@ -1,3 +1,11 @@
+ * @file
+ * @ingroup RTEMSFDisk
+ * This file defines the interface to a flash disk block device.
* flashdisk.h -- Flash disk block device implementation
@@ -19,13 +27,84 @@
- * The base name of the flash disks.
-#define RTEMS_FLASHDISK_DEVICE_BASE_NAME "/dev/fdd"
- * Flash disk specific ioctl request types. To use open the
- * device and issue the ioctl call.
+ * @defgroup RTEMSFDisk Flash Disk Device
+ * @ingroup rtems_blkdev
+ * Flash disk driver for RTEMS provides support for block based
+ * file systems on flash devices. The driver is not a flash file
+ * system nor does it try to compete with flash file systems. It
+ * currently does not journal how-ever block sequence numbering
+ * could be added to allow recovery of a past positions if
+ * a power down occurred while being updated.
+ * This flash driver provides block device support for most flash
+ * devices. The driver has been tested on NOR type devices such
+ * as the AMLV160 or M28W160. Support for NAND type devices may
+ * require driver changes to allow speedy recover of the block
+ * mapping data and to also handle the current use of word programming.
+ * Currently the page descriptors are stored in the first few pages
+ * of each segment.
+ * The driver supports devices, segments and pages. You provide
+ * to the driver the device descriptions as a table of device
+ * descriptors. Each device descriptor contain a table of
+ * segment descriptions or segment descriptors. The driver uses
+ * this information to manage the devices.
+ * A device is made up of segments. These are also called
+ * sectors or blocks. It is the smallest erasable part of a device.
+ * A device can have differing size segments at different
+ * offsets in the device. The segment descriptors support repeating
+ * segments that are continuous in the device. The driver breaks the
+ * segments up into pages. The first pages of a segment contain
+ * the page descriptors. A page descriptor hold the page flags,
+ * a CRC for the page of data and the block number the page
+ * holds. The block can appear in any order in the devices. A
+ * page is active if it hold a current block of data. If the
+ * used bit is set the page is counted as used. A page moves
+ * from erased to active to used then back to erased. If a block
+ * is written that is already in a page, the block is written to
+ * a new page the old page is flagged as used.
+ * At initialization time each segment's page descriptors are
+ * read into memory and scanned to determine the active pages,
+ * the used pages and the bad pages. If a segment has any erased
+ * pages it is queue on the available queue. If the segment has
+ * no erased pages it is queue on the used queue.
+ * The available queue is sorted from the least number available
+ * to the most number of available pages. A segment that has just
+ * been erased will placed at the end of the queue. A segment that
+ * has only a few available pages will be used sooner and once
+ * there are no available pages it is queued on the used queue.
+ * The used queue hold segments that have no available pages and
+ * is sorted from the least number of active pages to the most
+ * number of active pages.
+ * The driver is required to compact segments. Compacting takes
+ * the segment with the most number of available pages from the
+ * available queue then takes segments with the least number of
+ * active pages from the used queue until it has enough pages
+ * to fill the empty segment. As the active pages are moved
+ * they flagged as used and once the segment has only used pages
+ * it is erased.
+ * A flash block driver like this never knows if a page is not
+ * being used by the file-system. A typical file system is not
+ * design with the idea of erasing a block on a disk once it is
+ * not being used. The file-system will normally use a flag
+ * or a location as a marker to say that part of the disk is
+ * no longer in use. This means a number of blocks could be
+ * held in active pages but are no in use by the file system.
+ * The file system may also read blocks that have never been
+ * written to disk. This complicates the driver and may make
+ * the wear, usage and erase patterns harsher than a flash
+ * file system. The driver may also suffer from problems if
+ * power is lost.
+ * There are some flash disk specific IO control request types.
+ * To use open the device and issue the ioctl() call.
* @code
* int fd = open ("/dev/flashdisk0", O_WRONLY, 0);
@@ -41,7 +120,15 @@
* close (fd);
* @endcode
+ * @brief The base name of the flash disks.
+#define RTEMS_FLASHDISK_DEVICE_BASE_NAME "/dev/fdd"
#define RTEMS_FDISK_IOCTL_ERASE_DISK _IO('B', 128)
#define RTEMS_FDISK_IOCTL_COMPACT _IO('B', 129)
#define RTEMS_FDISK_IOCTL_ERASE_USED _IO('B', 130)
@@ -50,7 +137,7 @@
#define RTEMS_FDISK_IOCTL_PRINT_STATUS _IO('B', 133)
- * Flash Disk Monitoring Data allows a user to obtain
+ * @brief Flash Disk Monitoring Data allows a user to obtain
* the current status of the disk.
typedef struct rtems_fdisk_monitor_data
@@ -74,10 +161,9 @@ typedef struct rtems_fdisk_monitor_data
} rtems_fdisk_monitor_data;
- * Flash Segment Descriptor holds, number of continuous segments in the
- * device of this type, the base segment number in the device, the
- * address offset of the base segment in the device, and the size of
- * segment.
+ * @brief Flash Segment Descriptor holds, number of continuous segments in the
+ * device of this type, the base segment number in the device, the address
+ * offset of the base segment in the device, and the size of segment.
* Typically this structure is part of a table of segments in the
* device which is referenced in the flash disk configuration table.
@@ -93,7 +179,7 @@ typedef struct rtems_fdisk_segment_desc
} rtems_fdisk_segment_desc;
- * Return the number of kilo-bytes.
+ * @brief Return the number of kilo-bytes.
#define RTEMS_FDISK_KBYTES(_k) (UINT32_C(1024) * (_k))
@@ -103,8 +189,8 @@ typedef struct rtems_fdisk_segment_desc
struct rtems_fdisk_device_desc;
- * Flash Low Level driver handlers.
+ * @brief Flash Low Level driver handlers.
* Typically this structure is part of a table of handlers in the
* The reference is kept in the driver and used all the time to
@@ -245,10 +331,10 @@ typedef struct rtems_fdisk_driver_handlers
} rtems_fdisk_driver_handlers;
- * Flash Device Descriptor holds the segments in a device. The
- * placing of the segments in a device decriptor allows the
- * low level driver to share the segment descriptors for a
- * number of devices.
+ * @brief Flash Device Descriptor holds the segments in a device.
+ * The placing of the segments in a device decriptor allows the low level
+ * driver to share the segment descriptors for a number of devices.
@@ -263,7 +349,7 @@ typedef struct rtems_fdisk_device_desc
} rtems_fdisk_device_desc;
- * RTEMS Flash Disk configuration table used to initialise the
+ * @brief RTEMS Flash Disk configuration table used to initialise the
* driver.
* The unavailable blocks count is the number of blocks less than the
@@ -298,13 +384,22 @@ typedef struct rtems_flashdisk_config
const rtems_fdisk_device_desc* devices; /**< The device descriptions. */
uint32_t flags; /**< Set of flags to control
driver. */
- uint32_t unavail_blocks; /**< Number of blocks not
- available to the file sys. */
+ * Number of blocks not available to the file system. This number must be
+ * greater than or equal to the number of blocks in the largest segment to
+ * avoid starvation of erased blocks.
+ uint32_t unavail_blocks;
uint32_t compact_segs; /**< Max number of segs to
compact in one pass. */
- uint32_t avail_compact_segs; /**< The number of segments
- when compaction occurs
- when writing. */
+ * The number of segments when compaction occurs when writing. In case the
+ * number of segments in the available queue is less than or equal to this
+ * number the compaction process will be triggered. The available queue
+ * contains all segments with erased blocks.
+ uint32_t avail_compact_segs;
uint32_t info_level; /**< Default info level. */
} rtems_flashdisk_config;
@@ -352,15 +447,17 @@ rtems_fdisk_initialize (rtems_device_major_number major,
void* arg);
- * External reference to the configuration. Please supply.
+ * @brief External reference to the configuration. Please supply.
* Support is present in confdefs.h for providing this variable.
extern const rtems_flashdisk_config rtems_flashdisk_configuration[];
- * External reference to the number of configurations. Please supply.
+ * @brief External reference to the number of configurations. Please supply.
extern uint32_t rtems_flashdisk_configuration_size;
#endif
diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
index dc4da64..107f8b4 100644
--- a/cpukit/libblock/src/flashdisk.c
+++ b/cpukit/libblock/src/flashdisk.c
@@ -9,86 +9,11 @@
* $Id$
- * @file
- * Flash disk driver for RTEMS provides support for block based
- * file systems on flash devices. The driver is not a flash file
- * system nor does it try to compete with flash file systems. It
- * currently does not journal how-ever block sequence numbering
- * could be added to allow recovery of a past positions if
- * a power down occurred while being updated.
- * This flash driver provides block device support for most flash
- * devices. The driver has been tested on NOR type devices such
- * as the AMLV160 or M28W160. Support for NAND type devices may
- * require driver changes to allow speedy recover of the block
- * mapping data and to also handle the current use of word programming.
- * Currently the page descriptors are stored in the first few pages
- * of each segment.
- * The driver supports devices, segments and pages. You provide
- * to the driver the device descriptions as a table of device
- * descriptors. Each device descriptor contain a table of
- * segment descriptions or segment descriptors. The driver uses
- * this information to manage the devices.
- * A device is made up of segments. These are also called
- * sectors or blocks. It is the smallest erasable part of a device.
- * A device can have differing size segments at different
- * offsets in the device. The segment descriptors support repeating
- * segments that are continous in the device. The driver breaks the
- * segments up into pages. The first pages of a segment contain
- * the page descriptors. A page descriptor hold the page flags,
- * a CRC for the page of data and the block number the page
- * holds. The block can appear in any order in the devices. A
- * page is active if it hold a current block of data. If the
- * used bit is set the page is counted as used. A page moves
- * from erased to active to used then back to erased. If a block
- * is written that is already in a page, the block is written to
- * a new page the old page is flagged as used.
- * At initialisation time each segment's page descriptors are
- * read into memory and scanned to determine the active pages,
- * the used pages and the bad pages. If a segment has any erased
- * pages it is queue on the available queue. If the segment has
- * no erased pages it is queue on the used queue.
- * The available queue is sorted from the least number available
- * to the most number of available pages. A segment that has just
- * been erased will placed at the end of the queue. A segment that
- * has only a few available pages will be used sooner and once
- * there are no available pages it is queued on the used queue.
- * The used queue hold segments that have no available pages and
- * is sorted from the least number of active pages to the most
- * number of active pages.
- * The driver is required to compact segments. Compacting takes
- * the segment with the most number of available pages from the
- * available queue then takes segments with the least number of
- * active pages from the used queue until it has enough pages
- * to fill the empty segment. As the active pages are moved
- * they flagged as used and once the segment has only used pages
- * it is erased.
- * A flash block driver like this never knows if a page is not
- * being used by the file-system. A typical file system is not
- * design with the idea of erasing a block on a disk once it is
- * not being used. The file-system will normally use a flag
- * or a location as a marker to say that part of the disk is
- * no longer in use. This means a number of blocks could be
- * held in active pages but are no in use by the file system.
- * The file system may also read blocks that have never been
- * written to disk. This complicates the driver and may make
- * the wear, usage and erase patterns harsher than a flash
- * file system. The driver may also suffer from problems if
- * power is lost.
- * @note
* The use of pages can vary. The rtems_fdisk_seg_*_page set
* routines use an absolute page number relative to the segment
- * while all other page numbera are relative to the number of
+ * while all other page numbers are relative to the number of
* page descriptor pages a segment has. You need to add the
* number of page descriptor pages (pages_desc) to the page number
* when call the rtems_fdisk_seg_*_page functions.
More information about the rtems-vc
