[rtems commit] PR2040: libblock: Avoid erased blocks starvation
Sebastian Huber
sebh at rtems.org
Wed Mar 14 05:17:04 CDT 2012
Module: rtems
Branch: master
Commit: c08072ce31839ed0945d60a75429f273712b52dd
Changeset: http://git.rtems.org/rtems/commit/?id=c08072ce31839ed0945d60a75429f273712b52dd
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date: Wed Mar 14 08:45:53 2012 +0100
The compaction process needs erased blocks. It is only possible to
erase an entire segment. Thus in order to make a progress we always
need enough erased blocks to empty a used or available segment which can
be erased in turn. A (possibly the worst case) lower bound of erased
blocks is the block count of the largest segment. The number of
unavailable blocks specified by the configuration will be used to
determine the erase blocks starvation situation. The number of
unavailable blocks must be greater than or equal to the number of blocks
in the largest segment.
cpukit/libblock/src/flashdisk.c | 300 ++++++++++++++++++++++++---------------
1 files changed, 185 insertions(+), 115 deletions(-)
diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
index 0768e1c..54f544b 100644
--- a/cpukit/libblock/src/flashdisk.c
+++ b/cpukit/libblock/src/flashdisk.c
@@ -350,6 +350,12 @@ rtems_fdisk_printf (const rtems_flashdisk* fd, const char *format, ...)
return ret;
+static bool
+rtems_fdisk_is_erased_blocks_starvation (const rtems_flashdisk* fd)
+ return fd->erased_blocks < fd->unavail_blocks;
* Print a info message to the flash disk output and flush it.
@@ -1309,24 +1315,194 @@ rtems_fdisk_queue_segment (rtems_flashdisk* fd, rtems_fdisk_segment_ctl* sc)
+static int
+rtems_fdisk_recycle_segment (rtems_flashdisk* fd,
+ rtems_fdisk_segment_ctl* ssc,
+ rtems_fdisk_segment_ctl* dsc,
+ uint32_t *pages)
+ int ret;
+ uint32_t spage;
+ uint32_t used = 0;
+ uint32_t active = 0;
+ for (spage = 0; spage < ssc->pages; spage++)
+ uint32_t dst_pages;
+ rtems_fdisk_page_desc* spd = &ssc->page_descriptors[spage];
+ if (rtems_fdisk_page_desc_flags_set (spd, RTEMS_FDISK_PAGE_ACTIVE) &&
+ !rtems_fdisk_page_desc_flags_set (spd, RTEMS_FDISK_PAGE_USED))
+ rtems_fdisk_page_desc* dpd;
+ uint32_t dpage;
+ dpage = rtems_fdisk_seg_next_available_page (dsc);
+ dpd = &dsc->page_descriptors[dpage];
+ active++;
+ if (dpage >= dsc->pages)
+ rtems_fdisk_error ("recycle: %02d-%03d: " \
+ "no page desc available: %d",
+ dsc->device, dsc->segment,
+ rtems_fdisk_seg_pages_available (dsc));
+ dsc->failed = true;
+ rtems_fdisk_queue_segment (fd, dsc);
+ rtems_fdisk_segment_queue_push_head (&fd->used, ssc);
+ return EIO;
+#if RTEMS_FDISK_TRACE
+ rtems_fdisk_info (fd, "recycle: %02d-%03d-%03d=>%02d-%03d-%03d",
+ ssc->device, ssc->segment, spage,
+ dsc->device, dsc->segment, dpage);
+#endif
+ ret = rtems_fdisk_seg_copy_page (fd, ssc,
+ spage + ssc->pages_desc,
+ dsc,
+ dpage + dsc->pages_desc);
+ if (ret)
+ rtems_fdisk_error ("recycle: %02d-%03d-%03d=>" \
+ "%02d-%03d-%03d: " \
+ "copy page failed: %s (%d)",
+ dsc->device, dsc->segment, dpage,
+ strerror (ret), ret);
+ return ret;
+ *dpd = *spd;
+ ret = rtems_fdisk_seg_write_page_desc (fd,
+ dsc,
+ dpage, dpd);
+ if (ret)
+ "%02d-%03d-%03d: copy pd failed: %s (%d)",
+ return ret;
+ dsc->pages_active++;
+ * No need to set the used bit on the source page as the
+ * segment will be erased. Power down could be a problem.
+ * We do the stats to make sure everything is as it should
+ * be.
+ ssc->pages_active--;
+ ssc->pages_used++;
+ fd->blocks[spd->block].segment = dsc;
+ fd->blocks[spd->block].page = dpage;
+ * Place the segment on to the correct queue.
+ * Get new destination segment if necessary.
+ dst_pages = rtems_fdisk_seg_pages_available (dsc);
+ if (dst_pages == 0)
+ dsc = rtems_fdisk_seg_most_available (&fd->available);
+ if (!dsc)
+ rtems_fdisk_error ("recycle: no available dst segment");
+ return EIO;
+ (*pages)--;
+ else if (rtems_fdisk_page_desc_erased (spd))
+ --fd->erased_blocks;
+ else
+ used++;
+ rtems_fdisk_printf (fd, "ssc end: %d-%d: p=%ld, a=%ld, u=%ld",
+ pages, active, used);
+#endif
+ if (ssc->pages_active != 0)
+ rtems_fdisk_error ("compacting: ssc pages not 0: %d",
+ ssc->pages_active);
+ ret = rtems_fdisk_erase_segment (fd, ssc);
+ return ret;
* Compact the used segments to free what is available. Find the segment
- * with the most avalable number of pages and see if we have
+ * with the most available number of pages and see if we have
* used segments that will fit. The used queue is sorted on the least
* number of active pages.
static int
rtems_fdisk_compact (rtems_flashdisk* fd)
+ int ret;
+ rtems_fdisk_segment_ctl* dsc;
+ rtems_fdisk_segment_ctl* ssc;
uint32_t compacted_segs = 0;
+ uint32_t pages;
+ if (rtems_fdisk_is_erased_blocks_starvation (fd))
+ ssc = rtems_fdisk_segment_queue_pop_head (&fd->used);
+ if (!ssc)
+ ssc = rtems_fdisk_segment_queue_pop_head (&fd->available);
+ if (ssc)
+ if (dsc)
+ ret = rtems_fdisk_recycle_segment (fd, ssc, dsc, &pages);
+ if (ret)
+ return ret;
+ else
+ rtems_fdisk_error ("compacting: starvation");
+ return EIO;
+ else
+ rtems_fdisk_error ("compacting: nothing to recycle");
+ return EIO;
while (fd->used.head)
- rtems_fdisk_segment_ctl* dsc;
- rtems_fdisk_segment_ctl* ssc;
uint32_t dst_pages;
uint32_t segments;
- uint32_t pages;
rtems_fdisk_printf (fd, " compacting");
@@ -1390,121 +1566,11 @@ rtems_fdisk_compact (rtems_flashdisk* fd)
while (pages)
- uint32_t spage;
- int ret;
if (ssc)
- uint32_t used = 0;
- uint32_t active = 0;
- for (spage = 0; spage < ssc->pages; spage++)
- rtems_fdisk_page_desc* spd = &ssc->page_descriptors[spage];
- if (rtems_fdisk_page_desc_flags_set (spd, RTEMS_FDISK_PAGE_ACTIVE) &&
- !rtems_fdisk_page_desc_flags_set (spd, RTEMS_FDISK_PAGE_USED))
- rtems_fdisk_page_desc* dpd;
- uint32_t dpage;
- dpage = rtems_fdisk_seg_next_available_page (dsc);
- dpd = &dsc->page_descriptors[dpage];
- active++;
- if (dpage >= dsc->pages)
- rtems_fdisk_error ("compacting: %02d-%03d: " \
- "no page desc available: %d",
- dsc->device, dsc->segment,
- rtems_fdisk_seg_pages_available (dsc));
- dsc->failed = true;
- rtems_fdisk_queue_segment (fd, dsc);
- rtems_fdisk_segment_queue_push_head (&fd->used, ssc);
- return EIO;
-#if RTEMS_FDISK_TRACE
- rtems_fdisk_info (fd, "compacting: %02d-%03d-%03d=>%02d-%03d-%03d",
- ssc->device, ssc->segment, spage,
- dsc->device, dsc->segment, dpage);
-#endif
- ret = rtems_fdisk_seg_copy_page (fd, ssc,
- spage + ssc->pages_desc,
- dsc,
- dpage + dsc->pages_desc);
- if (ret)
- rtems_fdisk_error ("compacting: %02d-%03d-%03d=>" \
- "%02d-%03d-%03d: " \
- "copy page failed: %s (%d)",
- dsc->device, dsc->segment, dpage,
- strerror (ret), ret);
- return ret;
- *dpd = *spd;
- ret = rtems_fdisk_seg_write_page_desc (fd,
- dsc,
- dpage, dpd);
- if (ret)
- "%02d-%03d-%03d: copy pd failed: %s (%d)",
- return ret;
- dsc->pages_active++;
- * No need to set the used bit on the source page as the
- * segment will be erased. Power down could be a problem.
- * We do the stats to make sure everything is as it should
- * be.
- ssc->pages_active--;
- ssc->pages_used++;
- fd->blocks[spd->block].segment = dsc;
- fd->blocks[spd->block].page = dpage;
- * Place the segment on to the correct queue.
- pages--;
- else
- used++;
- rtems_fdisk_printf (fd, "ssc end: %d-%d: p=%ld, a=%ld, u=%ld",
- pages, active, used);
-#endif
- if (ssc->pages_active != 0)
- rtems_fdisk_error ("compacting: ssc pages not 0: %d",
- ssc->pages_active);
- ret = rtems_fdisk_erase_segment (fd, ssc);
if (ret)
return ret;
@@ -2031,6 +2097,10 @@ rtems_fdisk_write_block (rtems_flashdisk* fd,
rtems_fdisk_queue_segment (fd, sc);
+ rtems_fdisk_compact (fd);
return ret;
More information about the rtems-vc
