change log for rtems (2011-11-03)
rtems-vc at rtems.org
Thu Nov 3 00:10:14 CDT 2011
*ccj* (on branch rtems-4-10-branch):
2011-11-03 Chris Johns <chrisj at rtems.org>
PR 1948/filesystem
* libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-rtems.c:
Add support for mount passing an ASCIIZ string containing
configuration options.
* libblock/src/bdbuf.c: Fix state labels in trace output.
M 1.2346.2.104 cpukit/ChangeLog
M 1.52.2.1 cpukit/libblock/src/bdbuf.c
M 1.3.2.5 cpukit/libfs/src/rfs/rtems-rfs-file-system.h
M 1.4.2.3 cpukit/libfs/src/rfs/rtems-rfs-file-system.c
M 1.5.2.4 cpukit/libfs/src/rfs/rtems-rfs-format.c
M 1.9.2.4 cpukit/libfs/src/rfs/rtems-rfs-rtems.c
diff -u rtems/cpukit/ChangeLog:1.2346.2.103 rtems/cpukit/ChangeLog:1.2346.2.104
--- rtems/cpukit/ChangeLog:1.2346.2.103 Sat Oct 8 23:48:18 2011
+++ rtems/cpukit/ChangeLog Wed Nov 2 23:23:04 2011
@@ -1,3 +1,13 @@
+2011-11-03 Chris Johns <chrisj at rtems.org>
+ PR 1948/filesystem
+ * libfs/src/rfs/rtems-rfs-file-system.c,
+ libfs/src/rfs/rtems-rfs-file-system.h,
+ libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-rtems.c:
+ Add support for mount passing an ASCIIZ string containing
+ configuration options.
+ * libblock/src/bdbuf.c: Fix state labels in trace output.
2011-10-09 Ralf Corsépius <ralf.corsepius at rtems.org>
* libmisc/serdbg/serdbg.h (putDebugChar, getDebugChar):
diff -u rtems/cpukit/libblock/src/bdbuf.c:1.52 rtems/cpukit/libblock/src/bdbuf.c:1.52.2.1
--- rtems/cpukit/libblock/src/bdbuf.c:1.52 Mon May 17 21:14:05 2010
+++ rtems/cpukit/libblock/src/bdbuf.c Wed Nov 2 23:23:07 2011
@@ -291,7 +291,7 @@
rtems_bdbuf_show_users (const char* where, rtems_bdbuf_buffer* bd)
const char* states[] =
- { "EM", "FR", "CH", "AC", "AM", "MD", "SY", "TR" };
+ { "FR", "EM", "CH", "AC", "AM", "MD", "SY", "TR" };
printf ("bdbuf:users: %15s: [%" PRIu32 " (%s)] %td:%td = %" PRIu32 " %s\n",
where,
diff -u rtems/cpukit/libfs/src/rfs/rtems-rfs-file-system.h:1.3.2.4 rtems/cpukit/libfs/src/rfs/rtems-rfs-file-system.h:1.3.2.5
--- rtems/cpukit/libfs/src/rfs/rtems-rfs-file-system.h:1.3.2.4 Thu Jun 17 17:10:20 2010
+++ rtems/cpukit/libfs/src/rfs/rtems-rfs-file-system.h Wed Nov 2 23:23:07 2011
@@ -384,11 +384,14 @@
* @param name The device to open.
* @param fs The file system data filled in by this call.
* @param user A pointer to user data.
+ * @param flags The initial set of user flags for the file system.
+ * @param max_held_buffers The maximum number of buffers the RFS holds.
* @return int The error number (errno). No error if 0.
int rtems_rfs_fs_open (const char* name,
void* user,
uint32_t flags,
+ uint32_t max_held_buffers,
rtems_rfs_file_system** fs);
diff -u rtems/cpukit/libfs/src/rfs/rtems-rfs-file-system.c:1.4.2.2 rtems/cpukit/libfs/src/rfs/rtems-rfs-file-system.c:1.4.2.3
--- rtems/cpukit/libfs/src/rfs/rtems-rfs-file-system.c:1.4.2.2 Thu Jun 17 17:10:20 2010
+++ rtems/cpukit/libfs/src/rfs/rtems-rfs-file-system.c Wed Nov 2 23:23:07 2011
@@ -196,6 +196,7 @@
void* user,
uint32_t flags,
rtems_rfs_group* group;
@@ -224,7 +225,7 @@
rtems_chain_initialize_empty (&(*fs)->release_modified);
rtems_chain_initialize_empty (&(*fs)->file_shares);
- (*fs)->max_held_buffers = RTEMS_RFS_FS_MAX_HELD_BUFFERS;
+ (*fs)->max_held_buffers = max_held_buffers;
(*fs)->buffers_count = 0;
(*fs)->release_count = 0;
(*fs)->release_modified_count = 0;
diff -u rtems/cpukit/libfs/src/rfs/rtems-rfs-format.c:1.5.2.3 rtems/cpukit/libfs/src/rfs/rtems-rfs-format.c:1.5.2.4
--- rtems/cpukit/libfs/src/rfs/rtems-rfs-format.c:1.5.2.3 Mon Oct 11 16:12:48 2010
+++ rtems/cpukit/libfs/src/rfs/rtems-rfs-format.c Wed Nov 2 23:23:07 2011
@@ -465,7 +465,9 @@
* External API so returns -1.
- rc = rtems_rfs_fs_open (name, NULL, RTEMS_RFS_FS_FORCE_OPEN, &fs);
+ rc = rtems_rfs_fs_open (name, NULL,
+ RTEMS_RFS_FS_FORCE_OPEN | RTEMS_RFS_FS_NO_LOCAL_CACHE,
+ 0, &fs);
if (rc < 0)
printf ("rtems-rfs: format: file system open failed: %d: %s\n",
diff -u rtems/cpukit/libfs/src/rfs/rtems-rfs-rtems.c:1.9.2.3 rtems/cpukit/libfs/src/rfs/rtems-rfs-rtems.c:1.9.2.4
--- rtems/cpukit/libfs/src/rfs/rtems-rfs-rtems.c:1.9.2.3 Sun Jul 3 19:27:36 2011
+++ rtems/cpukit/libfs/src/rfs/rtems-rfs-rtems.c Wed Nov 2 23:23:07 2011
@@ -1268,8 +1268,40 @@
rtems_rfs_rtems_private* rtems;
rtems_rfs_file_system* fs;
+ uint32_t flags = 0;
+ uint32_t max_held_buffers = RTEMS_RFS_FS_MAX_HELD_BUFFERS;
+ const char* options = data;
int rc;
+ * Parse the options the user specifiies.
+ while (options)
+ printf ("options=%s\n", options);
+ if (strncmp (options, "hold-bitmaps",
+ sizeof ("hold-bitmaps") - 1) == 0)
+ flags |= RTEMS_RFS_FS_BITMAPS_HOLD;
+ else if (strncmp (options, "no-local-cache",
+ sizeof ("no-local-cache") - 1) == 0)
+ flags |= RTEMS_RFS_FS_NO_LOCAL_CACHE;
+ else if (strncmp (options, "max-held-bufs",
+ sizeof ("max-held-bufs") - 1) == 0)
+ max_held_buffers = strtoul (options + sizeof ("max-held-bufs"), 0, 0);
+ else
+ return rtems_rfs_rtems_error ("initialise: invalid option", EINVAL);
+ options = strchr (options, ',');
+ if (options)
+ ++options;
+ if (*options == '\0')
+ options = NULL;
rtems = malloc (sizeof (rtems_rfs_rtems_private));
if (!rtems)
return rtems_rfs_rtems_error ("initialise: local data", ENOMEM);
@@ -1291,7 +1323,7 @@
return rtems_rfs_rtems_error ("initialise: cannot lock access mutex", rc);
- rc = rtems_rfs_fs_open (mt_entry->dev, rtems, 0, &fs);
+ rc = rtems_rfs_fs_open (mt_entry->dev, rtems, flags, max_held_buffers, &fs);
if (rc)
free (rtems);
Generated by Deluxe Loginfo [http://www.codewiz.org/projects/index.html#loginfo] 2.122 by Bernardo Innocenti <bernie at develer.com>
URL: <http://www.rtems.org/pipermail/rtems-vc/attachments/20111103/5e972045/attachment.html>
More information about the rtems-vc
