change log for rtems (2010-11-25)
rtems-vc at rtems.org
Thu Nov 25 06:10:29 CST 2010
*sh*:
2010-11-25 Sebastian Huber <sebastian.huber at embedded-brains.de>
PR 1711/cpukit
* score/inline/rtems/score/chain.inl, score/src/chain.c: New functions
_Chain_Immutable_head(), _Chain_Immutable_tail(),
_Chain_Immutable_first(), and _Chain_Immutable_last(). The
Chain_Control is now a union to avoid casts. The function
_Chain_Is_empty() takes now a const pointer parameter.
M 1.2657 cpukit/ChangeLog
M 1.26 cpukit/score/include/rtems/score/chain.h
M 1.23 cpukit/score/inline/rtems/score/chain.inl
diff -u rtems/cpukit/ChangeLog:1.2656 rtems/cpukit/ChangeLog:1.2657
--- rtems/cpukit/ChangeLog:1.2656 Thu Nov 25 03:27:05 2010
+++ rtems/cpukit/ChangeLog Thu Nov 25 05:48:10 2010
@@ -1,5 +1,14 @@
+ PR 1711/cpukit
+ * score/inline/rtems/score/chain.inl, score/src/chain.c: New functions
+ _Chain_Immutable_head(), _Chain_Immutable_tail(),
+ _Chain_Immutable_first(), and _Chain_Immutable_last(). The
+ Chain_Control is now a union to avoid casts. The function
+ _Chain_Is_empty() takes now a const pointer parameter.
+2010-11-25 Sebastian Huber <sebastian.huber at embedded-brains.de>
* libfs/src/dosfs/fat_file.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_getchild.c,
posix/src/killinfo.c, score/inline/rtems/score/schedulerpriority.inl,
diff -u rtems/cpukit/score/include/rtems/score/chain.h:1.25 rtems/cpukit/score/include/rtems/score/chain.h:1.26
--- rtems/cpukit/score/include/rtems/score/chain.h:1.25 Mon Aug 23 11:10:53 2010
+++ rtems/cpukit/score/include/rtems/score/chain.h Thu Nov 25 05:48:11 2010
@@ -83,30 +83,24 @@
* manipulating the first and last elements on the chain.
* To accomplish this the @a Chain_Control structure is
* treated as two overlapping @ref Chain_Node structures.
- * The permanent head of the chain overlays a node structure on the
- * @a first and @a permanent_null fields. The permanent tail
- * of the chain overlays a node structure on the
- * @a permanent_null and @a last elements of the structure.
-typedef struct {
- /** This points to the first node on this chain. */
- Chain_Node *first;
- /** This field is always 0. */
- Chain_Node *permanent_null;
- /** This points to the last node on this chain. */
- Chain_Node *last;
+typedef union {
+ struct {
+ Chain_Node Node;
+ Chain_Node *fill;
+ } Head;
+ struct {
+ Chain_Node *fill;
+ Chain_Node Node;
+ } Tail;
} Chain_Control;
* @brief Chain initializer for an empty chain with designator @a name.
#define CHAIN_INITIALIZER_EMPTY(name) \
- (Chain_Node *) &(name).permanent_null, \
- NULL, \
- (Chain_Node *) &(name) \
+ { { { &(name).Tail.Node, NULL }, &(name).Head.Node } }
* @brief Chain definition for an empty chain with designator @a name.
diff -u rtems/cpukit/score/inline/rtems/score/chain.inl:1.22 rtems/cpukit/score/inline/rtems/score/chain.inl:1.23
--- rtems/cpukit/score/inline/rtems/score/chain.inl:1.22 Mon Aug 23 11:10:53 2010
+++ rtems/cpukit/score/inline/rtems/score/chain.inl Thu Nov 25 05:48:11 2010
@@ -122,7 +122,22 @@
Chain_Control *the_chain
- return (Chain_Node *) the_chain;
+ return &the_chain->Head.Node;
+/** @brief Return pointer to immutable Chain Head
+ * This function returns a pointer to the head node on the chain.
+ * @param[in] the_chain is the chain to be operated upon.
+ * @return This method returns the permanent head node of the chain.
+RTEMS_INLINE_ROUTINE const Chain_Node *_Chain_Immutable_head(
+ const Chain_Control *the_chain
/** @brief Return pointer to Chain Tail
@@ -137,7 +152,22 @@
- return (Chain_Node *) &the_chain->permanent_null;
+ return &the_chain->Tail.Node;
+/** @brief Return pointer to immutable Chain Tail
+ * This function returns a pointer to the last node on the chain.
+ * @return This method returns the permanent tail node of the chain.
+RTEMS_INLINE_ROUTINE const Chain_Node *_Chain_Immutable_tail(
/** @brief Return pointer to Chain's First node
@@ -153,7 +183,23 @@
- return the_chain->first;
+ return _Chain_Head( the_chain )->next;
+/** @brief Return pointer to immutable Chain's First node
+ * This function returns a pointer to the first node on the chain after the
+ * head.
+ * @return This method returns the first node of the chain.
+RTEMS_INLINE_ROUTINE const Chain_Node *_Chain_Immutable_first(
+ return _Chain_Immutable_head( the_chain )->next;
/** @brief Return pointer to Chain's Last node
@@ -169,7 +215,23 @@
- return the_chain->last;
+ return _Chain_Tail( the_chain )->previous;
+/** @brief Return pointer to immutable Chain's Last node
+ * This function returns a pointer to the last node on the chain just before
+ * the tail.
+ * @return This method returns the last node of the chain.
+RTEMS_INLINE_ROUTINE const Chain_Node *_Chain_Immutable_last(
+ return _Chain_Immutable_tail( the_chain )->previous;
/** @brief Return pointer the next node from this node
@@ -213,10 +275,11 @@
* false otherwise.
RTEMS_INLINE_ROUTINE bool _Chain_Is_empty(
- Chain_Control *the_chain
- return (the_chain->first == _Chain_Tail(the_chain));
+ return _Chain_Immutable_first( the_chain )
+ == _Chain_Immutable_tail( the_chain );
/** @brief Is this the First Node on the Chain
@@ -268,7 +331,8 @@
- return (the_chain->first == the_chain->last);
+ == _Chain_Immutable_last( the_chain );
/** @brief Is this Node the Chain Head
@@ -287,7 +351,7 @@
const Chain_Node *the_node
- return (the_node == _Chain_Head(the_chain));
+ return (the_node == _Chain_Head(the_chain));
/** @brief Is this Node the Chail Tail
@@ -303,7 +367,7 @@
- return (the_node == _Chain_Tail(the_chain));
+ return (the_node == _Chain_Tail(the_chain));
/** @brief Initialize this Chain as Empty
@@ -316,9 +380,12 @@
- the_chain->first = _Chain_Tail(the_chain);
- the_chain->permanent_null = NULL;
- the_chain->last = _Chain_Head(the_chain);
+ Chain_Node *head = _Chain_Head( the_chain );
+ Chain_Node *tail = _Chain_Tail( the_chain );
+ head->next = tail;
+ head->previous = NULL;
+ tail->previous = head;
/** @brief Extract this Node (unprotected)
@@ -360,15 +427,14 @@
- Chain_Node *return_node;
- Chain_Node *new_first;
+ Chain_Node *old_first = head->next;
+ Chain_Node *new_first = old_first->next;
- return_node = the_chain->first;
- new_first = return_node->next;
- the_chain->first = new_first;
- new_first->previous = _Chain_Head(the_chain);
+ head->next = new_first;
+ new_first->previous = head;
- return return_node;
+ return old_first;
/** @brief Get the First Node (unprotected)
@@ -435,13 +501,13 @@
- Chain_Node *old_last_node;
+ Chain_Node *old_last = tail->previous;
- the_node->next = _Chain_Tail(the_chain);
- old_last_node = the_chain->last;
- the_chain->last = the_node;
- old_last_node->next = the_node;
- the_node->previous = old_last_node;
+ the_node->next = tail;
+ tail->previous = the_node;
+ old_last->next = the_node;
+ the_node->previous = old_last;
/** @brief Prepend a Node (unprotected)
@@ -556,17 +622,19 @@
bool is_empty_now = true;
- Chain_Node *first = the_chain->first;
- if ( first != _Chain_Tail( the_chain ) ) {
- Chain_Node *new_first = first->next;
+ if ( old_first != tail ) {
- new_first->previous = _Chain_Head( the_chain );
- *the_node = first;
+ *the_node = old_first;
- is_empty_now = new_first == _Chain_Tail( the_chain );
+ is_empty_now = new_first == tail;
} else
*the_node = NULL;
Generated by Deluxe Loginfo [http://www.codewiz.org/projects/index.html#loginfo] 2.122 by Bernardo Innocenti <bernie at develer.com>
URL: <http://www.rtems.org/pipermail/rtems-vc/attachments/20101125/97af117a/attachment.html>
More information about the rtems-vc
