change log for rtems (2010-11-12)
rtems-vc at rtems.org
Fri Nov 12 08:11:53 CST 2010
*sh*:
2010-11-12 Sebastian Huber <sebastian.huber at embedded-brains.de>
* rtc/rtc-config.c: Fixed type.
M 1.57 c/src/lib/libbsp/arm/lpc24xx/ChangeLog
M 1.5 c/src/lib/libbsp/arm/lpc24xx/rtc/rtc-config.c
M 1.20 c/src/lib/libbsp/arm/lpc32xx/ChangeLog
M 1.4 c/src/lib/libbsp/arm/lpc32xx/rtc/rtc-config.c
diff -u rtems/c/src/lib/libbsp/arm/lpc24xx/ChangeLog:1.56 rtems/c/src/lib/libbsp/arm/lpc24xx/ChangeLog:1.57
--- rtems/c/src/lib/libbsp/arm/lpc24xx/ChangeLog:1.56 Thu Oct 14 04:34:06 2010
+++ rtems/c/src/lib/libbsp/arm/lpc24xx/ChangeLog Fri Nov 12 07:28:41 2010
@@ -1,3 +1,7 @@
+2010-11-12 Sebastian Huber <sebastian.huber at embedded-brains.de>
+ * rtc/rtc-config.c: Fixed type.
2010-10-14 Sebastian Huber <sebastian.huber at embedded-brains.de>
* include/lpc24xx.h, misc/system-clocks.c: Removed superfluous include
diff -u rtems/c/src/lib/libbsp/arm/lpc24xx/rtc/rtc-config.c:1.4 rtems/c/src/lib/libbsp/arm/lpc24xx/rtc/rtc-config.c:1.5
--- rtems/c/src/lib/libbsp/arm/lpc24xx/rtc/rtc-config.c:1.4 Tue Dec 15 09:20:46 2009
+++ rtems/c/src/lib/libbsp/arm/lpc24xx/rtc/rtc-config.c Fri Nov 12 07:28:41 2010
@@ -78,7 +78,7 @@
.deviceSetTime = lpc24xx_rtc_set_time
-unsigned long RTC_Count = LPC24XX_RTC_NUMBER;
+size_t RTC_Count = LPC24XX_RTC_NUMBER;
rtems_device_minor_number RTC_Minor = 0;
diff -u rtems/c/src/lib/libbsp/arm/lpc32xx/ChangeLog:1.19 rtems/c/src/lib/libbsp/arm/lpc32xx/ChangeLog:1.20
--- rtems/c/src/lib/libbsp/arm/lpc32xx/ChangeLog:1.19 Thu Oct 21 08:58:18 2010
+++ rtems/c/src/lib/libbsp/arm/lpc32xx/ChangeLog Fri Nov 12 07:29:14 2010
@@ -1,3 +1,7 @@
2010-10-21 Sebastian Huber <sebastian.huber at embedded-brains.de>
* include/tm27.h: New file.
diff -u rtems/c/src/lib/libbsp/arm/lpc32xx/rtc/rtc-config.c:1.3 rtems/c/src/lib/libbsp/arm/lpc32xx/rtc/rtc-config.c:1.4
--- rtems/c/src/lib/libbsp/arm/lpc32xx/rtc/rtc-config.c:1.3 Wed Jun 23 03:27:57 2010
+++ rtems/c/src/lib/libbsp/arm/lpc32xx/rtc/rtc-config.c Fri Nov 12 07:29:14 2010
@@ -124,7 +124,7 @@
.deviceSetTime = lpc32xx_rtc_set_time
-unsigned long RTC_Count = LPC32XX_RTC_COUNT;
+size_t RTC_Count = LPC32XX_RTC_COUNT;
*sh*:
* misc/system-clocks.c: Use define instead of function call to allow
smaller delays.
M 1.58 c/src/lib/libbsp/arm/lpc24xx/ChangeLog
M 1.12 c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c
diff -u rtems/c/src/lib/libbsp/arm/lpc24xx/ChangeLog:1.57 rtems/c/src/lib/libbsp/arm/lpc24xx/ChangeLog:1.58
--- rtems/c/src/lib/libbsp/arm/lpc24xx/ChangeLog:1.57 Fri Nov 12 07:28:41 2010
+++ rtems/c/src/lib/libbsp/arm/lpc24xx/ChangeLog Fri Nov 12 07:45:33 2010
@@ -1,5 +1,10 @@
+ * misc/system-clocks.c: Use define instead of function call to allow
+ smaller delays.
diff -u rtems/c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c:1.11 rtems/c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c:1.12
--- rtems/c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c:1.11 Thu Oct 14 04:34:06 2010
+++ rtems/c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c Fri Nov 12 07:45:33 2010
@@ -62,7 +62,7 @@
void lpc24xx_micro_seconds_delay(unsigned us)
unsigned start = lpc24xx_timer();
- unsigned delay = us * (lpc24xx_cclk() / 1000000);
+ unsigned delay = us * (LPC24XX_CCLK / 1000000);
unsigned elapsed = 0;
do {
Generated by Deluxe Loginfo [http://www.codewiz.org/projects/index.html#loginfo] 2.122 by Bernardo Innocenti <bernie at develer.com>
URL: <http://www.rtems.org/pipermail/rtems-vc/attachments/20101112/bebe9f5a/attachment.html>
More information about the rtems-vc
