change log for rtems (2010-06-18)
rtems-vc at rtems.org
Fri Jun 18 11:13:40 CDT 2010
*ralf* (on branch rtems-4-10-branch):
2010-06-18 Ralf Corsépius <ralf.corsepius at rtems.org>
* rtems/include/rtems/rtems/object.h,
rtems/src/rtemsobjectidapimaximum.c:
Let rtems_object_id_api_maximum() return OBJECTS_APIS_LAST.
M 1.2346.2.41 cpukit/ChangeLog
M 1.9.2.1 cpukit/rtems/include/rtems/rtems/object.h
M 1.2.2.1 cpukit/rtems/src/rtemsobjectidapimaximum.c
diff -u rtems/cpukit/ChangeLog:1.2346.2.40 rtems/cpukit/ChangeLog:1.2346.2.41
--- rtems/cpukit/ChangeLog:1.2346.2.40 Fri Jun 18 05:03:49 2010
+++ rtems/cpukit/ChangeLog Fri Jun 18 08:29:29 2010
@@ -1,5 +1,11 @@
+ * rtems/include/rtems/rtems/object.h,
+ rtems/src/rtemsobjectidapimaximum.c:
+ Let rtems_object_id_api_maximum() return OBJECTS_APIS_LAST.
+2010-06-18 Ralf Corsépius <ralf.corsepius at rtems.org>
* libnetworking/rtems/mkrootfs.h: doxygen cosmetics.
* libnetworking/netinet/if_ether.c: Misc. 64bit fixes from FreeBSD.
* libfs/src/nfsclient/src/rpcio.c: Misc. 64bit fixes.
diff -u rtems/cpukit/rtems/include/rtems/rtems/object.h:1.9 rtems/cpukit/rtems/include/rtems/rtems/object.h:1.9.2.1
--- rtems/cpukit/rtems/include/rtems/rtems/object.h:1.9 Sun Nov 29 05:55:14 2009
+++ rtems/cpukit/rtems/include/rtems/rtems/object.h Fri Jun 18 08:29:29 2010
@@ -240,7 +240,7 @@
* @note A body is also provided.
#define rtems_object_id_api_maximum() \
- OBJECTS_ITRON_API
+ OBJECTS_APIS_LAST
* @brief Get Lowest Valid Class Value
diff -u rtems/cpukit/rtems/src/rtemsobjectidapimaximum.c:1.2 rtems/cpukit/rtems/src/rtemsobjectidapimaximum.c:1.2.2.1
--- rtems/cpukit/rtems/src/rtemsobjectidapimaximum.c:1.2 Mon Nov 23 08:53:04 2009
+++ rtems/cpukit/rtems/src/rtemsobjectidapimaximum.c Fri Jun 18 08:29:29 2010
@@ -22,5 +22,5 @@
#undef rtems_object_id_api_maximum
int rtems_object_id_api_maximum(void)
- return OBJECTS_ITRON_API;
+ return OBJECTS_APIS_LAST;
Generated by Deluxe Loginfo [http://www.codewiz.org/projects/index.html#loginfo] 2.122 by Bernardo Innocenti <bernie at develer.com>
URL: <http://www.rtems.org/pipermail/rtems-vc/attachments/20100618/de383e7c/attachment.html>
More information about the rtems-vc
