change log for rtems (2010-08-20)
rtems-vc at rtems.org rtems-vc at rtems.org
Fri Aug 20 13:10:20 CDT 2010
 *joel*:
2010-08-20	Joel Sherrill <joel.sherrill at oarcorp.com>
	PR 1682/bsps
	* startup/bspstart.c: Add BSP_poll_char.
M   1.12  c/src/lib/libbsp/powerpc/beatnik/ChangeLog
M    1.2  c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c
diff -u rtems/c/src/lib/libbsp/powerpc/beatnik/ChangeLog:1.11 rtems/c/src/lib/libbsp/powerpc/beatnik/ChangeLog:1.12
--- rtems/c/src/lib/libbsp/powerpc/beatnik/ChangeLog:1.11	Tue Jun 29 13:52:46 2010
+++ rtems/c/src/lib/libbsp/powerpc/beatnik/ChangeLog	Fri Aug 20 12:59:41 2010
@@ -1,3 +1,8 @@
+2010-08-20	Joel Sherrill <joel.sherrill at oarcorp.com>
+	PR 1682/bsps
+	* startup/bspstart.c: Add BSP_poll_char.
 2010-06-29	Joel Sherrill <joel.sherrill at oarcorp.com>
 	* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
diff -u rtems/c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c:1.1 rtems/c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c:1.2
--- rtems/c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c:1.1	Thu Dec  3 10:56:50 2009
+++ rtems/c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c	Fri Aug 20 12:59:41 2010
@@ -54,7 +54,8 @@
 #define SHOW_MORE_INIT_SETTINGS
-BSP_output_char_function_type BSP_output_char = BSP_output_char_via_serial;
+BSP_output_char_function_type     BSP_output_char = BSP_output_char_via_serial;
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
 extern char *BSP_build_date;
 extern void bsp_cleanup(void);
Generated by Deluxe Loginfo [http://www.codewiz.org/projects/index.html#loginfo] 2.122 by Bernardo Innocenti <bernie at develer.com>
URL: <http://www.rtems.org/pipermail/rtems-vc/attachments/20100820/b8735a40/attachment.html>
More information about the rtems-vc mailing list
