change log for rtems (2010-08-20)
rtems-vc at rtems.org
Fri Aug 20 09:10:49 CDT 2010
*ralf*:
2010-08-16 Ralf Corsépius <ralf.corsepius at rtems.org>
* sapi/include/rtems/chain.h: Move extern "C".
M 1.2573 cpukit/ChangeLog
M 1.4 cpukit/sapi/include/rtems/chain.h
diff -u rtems/cpukit/ChangeLog:1.2572 rtems/cpukit/ChangeLog:1.2573
--- rtems/cpukit/ChangeLog:1.2572 Fri Aug 20 04:08:04 2010
+++ rtems/cpukit/ChangeLog Fri Aug 20 08:26:54 2010
@@ -1,3 +1,7 @@
+2010-08-16 Ralf Corsépius <ralf.corsepius at rtems.org>
+ * sapi/include/rtems/chain.h: Move extern "C".
2010-08-16 Alin Rus <alin.codejunkie at gmail.com>
* posix/include/aio.h: Add LIO_SYNC.
diff -u rtems/cpukit/sapi/include/rtems/chain.h:1.3 rtems/cpukit/sapi/include/rtems/chain.h:1.4
--- rtems/cpukit/sapi/include/rtems/chain.h:1.3 Mon Nov 30 07:20:29 2009
+++ rtems/cpukit/sapi/include/rtems/chain.h Fri Aug 20 08:26:55 2010
@@ -22,13 +22,13 @@
#ifndef _RTEMS_CHAIN_H
#define _RTEMS_CHAIN_H
+#include <rtems/system.h>
+#include <rtems/score/chain.h>
#ifdef __cplusplus
extern "C" {
#endif
-#include <rtems/system.h>
-#include <rtems/score/chain.h>
* @typedef rtems_chain_node
*ralf*:
* posix/include/aio.h: Separate LIO-modes from LIO-opcodes (From
freebsd).
M 1.2574 cpukit/ChangeLog
M 1.16 cpukit/posix/include/aio.h
diff -u rtems/cpukit/ChangeLog:1.2573 rtems/cpukit/ChangeLog:1.2574
--- rtems/cpukit/ChangeLog:1.2573 Fri Aug 20 08:26:54 2010
+++ rtems/cpukit/ChangeLog Fri Aug 20 08:30:31 2010
@@ -1,5 +1,10 @@
+ * posix/include/aio.h: Separate LIO-modes from LIO-opcodes (From
+ freebsd).
diff -u rtems/cpukit/posix/include/aio.h:1.15 rtems/cpukit/posix/include/aio.h:1.16
--- rtems/cpukit/posix/include/aio.h:1.15 Fri Aug 20 04:08:05 2010
+++ rtems/cpukit/posix/include/aio.h Fri Aug 20 08:30:32 2010
@@ -46,15 +46,22 @@
/* lio_listio() options */
+ * LIO modes
#define LIO_WAIT 0 /* calling process is to suspend until the */
/* operation is complete */
#define LIO_NOWAIT 1 /* calling process is to continue execution while */
/* the operation is performed and no notification */
/* shall be given when the operation is completed */
-#define LIO_READ 2 /* request a read() */
-#define LIO_WRITE 3 /* request a write() */
-#define LIO_NOP 4 /* no transfer is requested */
-#define LIO_SYNC 5 /* needed by aio_fsync() */
+ * LIO opcodes
+#define LIO_NOP 0 /* no transfer is requested */
+#define LIO_READ 1 /* request a read() */
+#define LIO_WRITE 2 /* request a write() */
+#define LIO_SYNC 3 /* needed by aio_fsync() */
* 6.7.1.1 Asynchronous I/O Control Block, P1003.1b-1993, p. 151
*ralf*:
* posix/include/rtems/posix/aio_misc.h: Remove rtems_aio_request_s,
rtems_aio_request_chain_s, rtems_aio_queue_s;
M 1.2575 cpukit/ChangeLog
M 1.4 cpukit/posix/include/rtems/posix/aio_misc.h
diff -u rtems/cpukit/ChangeLog:1.2574 rtems/cpukit/ChangeLog:1.2575
--- rtems/cpukit/ChangeLog:1.2574 Fri Aug 20 08:30:31 2010
+++ rtems/cpukit/ChangeLog Fri Aug 20 08:32:28 2010
@@ -1,5 +1,7 @@
+ * posix/include/rtems/posix/aio_misc.h: Remove rtems_aio_request_s,
+ rtems_aio_request_chain_s, rtems_aio_queue_s;
freebsd).
diff -u rtems/cpukit/posix/include/rtems/posix/aio_misc.h:1.3 rtems/cpukit/posix/include/rtems/posix/aio_misc.h:1.4
--- rtems/cpukit/posix/include/rtems/posix/aio_misc.h:1.3 Fri Aug 20 04:08:05 2010
+++ rtems/cpukit/posix/include/rtems/posix/aio_misc.h Fri Aug 20 08:32:28 2010
@@ -27,7 +27,7 @@
#endif
/* Actual request being processed */
- typedef struct rtems_aio_request_s
+ typedef struct
int policy; /* If _POSIX_PRIORITIZED_IO and
_POSIX_PRIORITY_SCHEDULING are defined */
@@ -37,7 +37,7 @@
struct aiocb *aiocbp; /* aio control block */
} rtems_aio_request;
- typedef struct rtems_aio_request_chain_s
+ typedef struct
int fildes; /* file descriptor to be processed */
int new_fd; /* if this is a newly created chain */
@@ -48,7 +48,7 @@
} rtems_aio_request_chain;
- typedef struct rtems_aio_queue_s
+ typedef struct
pthread_mutex_t mutex;
pthread_cond_t new_req;
Generated by Deluxe Loginfo [http://www.codewiz.org/projects/index.html#loginfo] 2.122 by Bernardo Innocenti <bernie at develer.com>
URL: <http://www.rtems.org/pipermail/rtems-vc/attachments/20100820/e5daa22a/attachment.html>
More information about the rtems-vc
