change log for rtems (2010-08-18)
rtems-vc at rtems.org
Wed Aug 18 05:10:23 CDT 2010
*ccj*:
2010-08-18 Chris Johns <chrisj at rtems.org>
PR 1677/filesystem
* libfs/src/imfs/imfs_creat.c: Fix creating of a file. Lost in the
change from a switch statement.
M 1.2570 cpukit/ChangeLog
M 1.21 cpukit/libfs/src/imfs/imfs_creat.c
diff -u rtems/cpukit/ChangeLog:1.2569 rtems/cpukit/ChangeLog:1.2570
--- rtems/cpukit/ChangeLog:1.2569 Mon Aug 16 09:09:37 2010
+++ rtems/cpukit/ChangeLog Wed Aug 18 04:58:14 2010
@@ -1,3 +1,9 @@
+2010-08-18 Chris Johns <chrisj at rtems.org>
+ PR 1677/filesystem
+ * libfs/src/imfs/imfs_creat.c: Fix creating of a file. Lost in the
+ change from a switch statement.
2010-08-16 Ralf Corsépius <ralf.corsepius at rtems.org>
* posix/include/rtems/posix/aio_misc.h: Remove
diff -u rtems/cpukit/libfs/src/imfs/imfs_creat.c:1.20 rtems/cpukit/libfs/src/imfs/imfs_creat.c:1.21
--- rtems/cpukit/libfs/src/imfs/imfs_creat.c:1.20 Mon Aug 2 13:27:22 2010
+++ rtems/cpukit/libfs/src/imfs/imfs_creat.c Wed Aug 18 04:58:15 2010
@@ -76,12 +76,11 @@
} else if ( type == IMFS_LINEAR_FILE ) {
node->info.linearfile.size = 0;
node->info.linearfile.direct = 0;
- if ( type == IMFS_MEMORY_FILE ) {
+ } else if ( type == IMFS_MEMORY_FILE ) {
node->info.file.size = 0;
node->info.file.indirect = 0;
node->info.file.doubly_indirect = 0;
node->info.file.triply_indirect = 0;
} else if ( type == IMFS_FIFO ) {
node->info.fifo.pipe = NULL;
} else {
Generated by Deluxe Loginfo [http://www.codewiz.org/projects/index.html#loginfo] 2.122 by Bernardo Innocenti <bernie at develer.com>
URL: <http://www.rtems.org/pipermail/rtems-vc/attachments/20100818/d64c32b3/attachment.html>
More information about the rtems-vc
