MCF5485EVB Board Console problems
Chris Xenophontos
cxenophontos at hammers.com
Mon May 7 08:04:50 CDT 2012
We have no output on console terminal when starting application. When
disabling terminal driver, and using printk, we have output on
console, and our application runs.
I did not run ./bootstrap after making the changes - is that what is needed?
thanks
On Mon, May 7, 2012 at 8:57 AM, Sebastian Huber
> On 05/07/2012 02:52 PM, Chris Xenophontos wrote:
>> Continuing with our console problem on MCF5485EVB, I incorporated
>> Sebastian's changes (config.ac and bspstart.c).
>> We have the same problem, i.e, application won't initialize with
> What means "application won't initialize" exactly? Have you done a
> bootstrap of the sources after the git update? Reflect the values in your
> bspopts.h the update?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
More information about the rtems-users
