Problem in Integration of Analog / Digital Drivce driver with RTEMS for MVME162-522A
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Thu Mar 29 02:30:14 CDT 2012
Hi,
it seems you didn't get yesterdays answers completely. May I point you to:
http://www.rtems.org/pipermail/rtems-users/2012-March/009774.html
and (don't forget it):
http://www.rtems.org/pipermail/rtems-users/2012-March/009775.html
This should (re-)generate the relevant automake* and configure files,
even for the GIT checkout.
If you have problems with these solutions, could you please post the
output of the tool calls?
wkr,
Thomas.
Am 29.03.2012 08:59, schrieb AJAI KUMAR MEDHAVI:
> Hi,
> But my queries are still pending.Please provide your suggestions, based on
> my addition and modifications in condefs.h, mvme162\makefile.am :
> 1.why makmefile.in and preinstall.am are not updating (by generating
> automatically by automake) as per modifications done in makefile.am
> I believe that makefile.in and preinstall.am have to be automatically
> get modified once we build RTEMS with modified makefile.am
> 2. What are the ways/procedures to get modified makefile.in and preinstall.am
> 3. Whether I have to modify some other makefiles / configuration files
> One more thing, Presently I am using RTEMS-4.10.2 version ( having
> "configure", configure.in, makefile.in and and preinstall.am files) In
> which I am facing IO drivers merger problem. Presently I am building RTEMS
> using ./configure with options( like --target=m68k-rtems4.10,
> --enable-rtemsbsp=mvme162 etc) and "make all"
> Now I wish to try to build RTEMS-4.10.2 ( from http://git.rtems.org/
> rtems). But it does not have "configure" file. I am not able to configure.
> Please let me know how to configure, build and make it.
> Kindly look into the problem and provide your valueable suggestions.
> Anticipating earliest reply
> Warm Regards
> MEDHAVI
>> My recollection would indicate these peripherals are not on the 162 board.
>> These never should have been merged into the rtems source tree and
>> modifying confdefs.h to get them is not riht unless you are proposing
>> standard ways for everyone to follow.
>> Build the drivers in your application space somehow and add them with the
>> confdefs.h parameter which is named something like
>> CONFIGURE_EXTRA_APPLICATION_DRIVERS.
>> --joel
>> AJAI KUMAR MEDHAVI <akmedhavi at rrcat.gov.in> wrote:
>>> Hi,
>>> I%2
> rtems-users mailing list
> rtems-users at rtems.org
Embedded Brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax: +49-89-18908079-9
More information about the rtems-users
