Building project - Eclipse
Gedare Bloom
gedare at rtems.org
Thu Mar 15 12:12:09 CDT 2012
On Thu, Mar 15, 2012 at 1:01 PM, Binkowski, Cassio <cassioiks at gmail.com> wrote:
> I think I have it now. But I had to do the whole process as ROOT.
Odd. Maybe you needed root privileges for installing RTEMS though..
> Now what I got in Eclipse is the following:
> **** Build of configuration RTEMS Executable Configuration for project test
> make all
> Building file: ../scr/init.c
> Invoking: RTEMS C Compiler
> /opt/rtems-4.11/bin/sparc-rtems4.11-gcc
> -B/opt/rtems-4.11/sparc-rtems4.11/sis/lib/ -specs bsp_specs -qrtems
> -mcpu=cypress -Os -g -Wall -c -fmessage-length=0 -pipe -MMD -MP
> -MF"scr/init.d" -MT"scr/init.d" -o "scr/init.o" "../scr/init.c"
> In file included from ../scr/init.c:12:0:
> /opt/rtems-4.11/sparc-rtems4.11/sis/lib/include/rtems/confdefs.h:2434:6:
> error: #error "CONFIGURATION ERROR: No tasks or threads configured!!"
> /opt/rtems-4.11/sparc-rtems4.11/sis/lib/include/rtems/confdefs.h:2446:2:
> error: #error "CONFIGURATION ERROR: No initialization tasks or threads
> configured!!"
> /opt/rtems-4.11/sparc-rtems4.11/sis/lib/include/rtems/confdefs.h:2496:6:
> error: #error "CONFIGURATION ERROR: Do you want the clock driver or not?!?"
> ../scr/init.c: In function 'init_task':
> ../scr/init.c:30:18: error: 'RTEMS_STATUS_SUCCESSFUL' undeclared (first use
> in this function)
> ../scr/init.c:30:18: note: each undeclared identifier is reported only once
> for each function it appears in
> ../scr/init.c:31:5: warning: implicit declaration of function 'printf'
> [-Wimplicit-function-declaration]
> ../scr/init.c:31:5: warning: incompatible implicit declaration of built-in
> function 'printf' [enabled by default]
> ../scr/init.c:32:5: warning: implicit declaration of function 'exit'
> ../scr/init.c:32:5: warning: incompatible implicit declaration of built-in
> function 'exit' [enabled by default]
> ../scr/init.c:37:5: warning: incompatible implicit declaration of built-in
> ../scr/init.c:38:5: warning: incompatible implicit declaration of built-in
> ../scr/init.c:41:31: error: 'SELF' undeclared (first use in this function)
> ../scr/init.c:42:3: warning: incompatible implicit declaration of built-in
> ../scr/init.c:43:3: warning: incompatible implicit declaration of built-in
> ../scr/init.c: At top level:
> ../scr/init.c:65:0: warning: "CONFIGURE_MAXIMUM_TASKS" redefined [enabled by
> default]
> /opt/rtems-4.11/sparc-rtems4.11/sis/lib/include/rtems/confdefs.h:1353:0:
> note: this is the location of the previous definition
> make: *** [scr/init.o] Error 1
> **** Build Finished ****
> I have these includes at the top:
> #include <bsp.h>
> #include <rtems.h>
> #include <rtems/confdefs.h>
> Can you please help?
If your application defines some configure variables, for example
#define CONFIGURE_MAXIMUM_TASKS 20
It should do so before including confdefs.h. When the confdefs.h
header file is included it checks to see which configure variables are
undefined and defines some defaults. Without looking at your code, I
would guess that you are including confdefs.h before you are defining
configure variables.
-Gedare
> rtems-users mailing list
> rtems-users at rtems.org
More information about the rtems-users
