Building project - Eclipse
Sebastian Huber
Wed Mar 14 07:48:16 CDT 2012
On 03/14/2012 01:35 PM, Binkowski, Cassio wrote:
> On Wed, Mar 14, 2012 at 4:36 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 03/13/2012 11:11 PM, Binkowski, Cassio wrote:
> On Tue, Mar 13, 2012 at 5:53 PM, Binkowski, Cassio <cassioiks at gmail.com
> <mailto:cassioiks at gmail.com>
> <mailto:cassioiks at gmail.com <mailto:cassioiks at gmail.com>>> wrote:
> On Tue, Mar 13, 2012 at 5:28 PM, Sebastian Huber
> <sebastian.huber at embedded-__brains.de
> <mailto:sebastian.huber at __embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> On 13/03/12 19:00, Binkowski, Cassio wrote:
> On Tue, Mar 13, 2012 at 11:10 AM, Sebastian Huber<
> sebastian.huber at embedded-____brains.de
> <mailto:sebastian.huber at embedded-__brains.de>
> On 03/13/2012 05:07 PM, Binkowski, Cassio wrote:
> What is the build directory name?
> It is actually build.
> /home/rtems/build
> The prefix must not be a subdirectory of the build
> directory.
> I don't understand. Can you then point me the direction?
> Thanks
> In another mail you write this:
> ~/rtems-4.11-work/rtems/____configure --target=sparc-rtems4.11
> --disable-posix
> --disable-networking --disable-cxx --enable-rtemsbsp=sis
> --enable-tests=samples
> --prefix=/home/rtems/build/____sparc-rtems4.11/sis
> /home/rtems/build
> Ok. It is correct.
> => your prefix is a subdirectory of the build tree
> This makes no sense and is wrong. Why not simply use the
> default prefix?
> But the default prefix Joel Sherril provided is the one that is
> pointing
> the the /sparc-rtems4.11/sis
> What do you have for default?
> /home/rtems/bild is where I have all things buit on.
> I have configured it with prefix=/opt/rtems-4.11, still getting errors
> in Eclipse.
> Quite frankly, you are so sparse with information, who should I know what
> "I have configured" is in your case?
> Just for clarification:
> Tools path: /opt/rtems-4.11
> Source path: /home/rtems/rtems-4.11-work/__rtems
> Build path: /home/rtems/build
> Can you please advise?
> cd
> rm -rf build
> mkdir build
> cd build
> /home/rtems/rtems-4.11-work/__rtems/configure --target=sparc-rtems4.11
> --prefix=/opt/rtems-4.11 --disable-posix --disable-cxx
> --enable-rtemsbsp=sis --enable-tests=samples --disable-networking
> make
> make install
> If you get errors in this procedure fix them first. You need an installed
> BSP before you start with Eclipse!
> When I "make install", in the last lines, I get that it entered a few
> directories but there was nothing to do there.
> Is this a bad sign?
It might help to post these last lines.
I case the above steps were successful, you should have something like this
find /opt/rtems-4.11/sparc-rtems4.11/sis/
/opt/rtems-4.11/sparc-rtems4.11/sis/lib
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/no-dpmem.rel
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/nfs.rel
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/rpcio.rel
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/libz.a
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/no-mp.rel
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/libsapi.a
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/librtemsbsp.a
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/linkcmds
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/bsp_specs
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/no-io.rel
/opt/rtems-4.11/sparc-rtems4.11/sis/tests
/opt/rtems-4.11/sparc-rtems4.11/sis/tests/runtest
/opt/rtems-4.11/sparc-rtems4.11/sis/make
/opt/rtems-4.11/sparc-rtems4.11/sis/make/target.cfg
/opt/rtems-4.11/sparc-rtems4.11/sis/make/bsp.cfg
/opt/rtems-4.11/sparc-rtems4.11/sis/Makefile.inc
> The prefix for the configure command should then be located at the tools path
> (/opt/rtems-4.11) ?
Yes, this is the default.
> What's the correct location for Base path and BSP path in Eclipse?
Base path: "/opt/rtems-4.11"
BSP path: "/opt/rtems-4.11/sparc-rtems4.11/sis"
> Please tell me what do you do that made it work for you.
> I am using the CentOS virtual machine, just in case.
> Regards
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
More information about the rtems-users
