problem on x86 io driver test complie
zhoupeng zpeng563 at 126.com
Mon Mar 5 09:21:20 CST 2012
hello,everyone
Recently , i write a driver to operate x86(pc104) io port .The data transmission is base on isa bus. When i complie my program.Some errors were found:
error:bsp/DIO.h :No such file or directory
error:DIO1_DRIVER_TABLE_ENTRY undeclared here (not in a function)
I think the second error is coursed by the first one . I don't know wheather my DIO.h is put on wrong place or didn't give the write search path. By inorder to do a test ,i used the Makefie of "hello_world".directly.
can you help me to slove this problem. Thank you!
Best Regard!
zhoupeng
URL: <http://www.rtems.org/pipermail/rtems-users/attachments/20120305/0e9067af/attachment-0001.html>
More information about the rtems-users mailing list
