Status of pkg-config support for RTEMS BSPs
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Mar 2 02:36:38 CST 2012
If it can be used even when you build and install a single BSP, then it has a use case. It provides a standard mechanism to ask for BSP specific parameters. This is useful to avoid copying the settings into user applications.
Ralf.. I would encourage you to put together a status report, wish list and instructions.
If peoplpe don't know about it thry won't help
Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
>On 03/02/2012 06:07 AM, Wendell Silva wrote:
>> Oops! Now that I've carefully read the comment in the .pc file, I just
>> realized that pkg-config is experimental.
>> (LOL).
>LOL - This sentence is a bit of an understatement ;)
>Reality is, pkg-config support has never been finished, because
>- pkg-config support so far was widely ignored my other RTEMS developers
>and my personal "one-man show".
>- pkg-config support did not get the attention by the RTEMS community,
>it would have needed. I am assuming, the common RTEMS user doesn't even
>know pkg-config and therefore doesn't know about the advantages it would
>provide.
>- it's not yet possible to ship RTEMS binary packages, which would be
>the situation pkg-config should unfold its advantages.
>- pkg-config's development went a winding road, which had caused
>confusions and unclarity on many implementation details in for the RTEMS
>use-case.
>In short: RTEMS's pkg-config support in its current state is broken and
>would need more attention.
> However, I regret, ATM, I am closer to removing it than to making it
>functional, because I am personally disappointed about the apparent lack
>of interest it has received.
>Ralf
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-users
More information about the rtems-users
