'CLOCK_THREAD_CPUTIME' undeclared
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 27 11:42:42 CST 2012
Please fix the wiki page to point to the new images.
I will delete the old ones when I get home.
Gedare Bloom <gedare at rtems.org> wrote:
>you might have better luck with the new VM at
>http://wiki.rtems.org/wiki/index.php/Virtual_Machines_for_RTEMS_Development
>the sourceforge image was probably uploaded awhile ago...
>On Sun, Feb 26, 2012 at 7:39 AM, Fered <a_Fered at yahoo.com> wrote:
>> On Yek-shanbe 07 Esfand 1390 11:36:48 Ralf Corsepius wrote:
>>> On 02/26/2012 09:52 AM, Fered wrote:
>>> > Hi;
>>> > I'm using Fedora image, contains RTEMS11 and uploaded in sorceforge.
>>> I don't understand what you are referring to, here.
>>> > After doing instructions in rtems website, I have some errors.
>>> > Log files are uploaded here:
>>> > http://www.mediafire.com/?7q2h3oifa2qrol1
>>> > Can anyone says me what's the problem?
>>> From your logs:
>>> /home/rtems/rtems-4.11-work/rtems/c/src/../../cpukit/posix/src/clocksettime.
>>> c: In function 'clock_settime':
>>> c:48:25: error: 'CLOCK_PROCESS_CPUTIME' undeclared (first use in this
>>> function) ...
>>> CLOCK_PROCESS_CPUTIME was removed from the rtems-4.11 toolchains.
>>> => You are facing an incompatibility between the RTEMS toolchains you
>>> are using and the version of RTEMS you are trying to build
>>> Ralf
>> Thank you.
>> I'm using toolchains, are installed on the image I dowloaded. Just I upgraded
>> Fedora packages as the instructions in rtems website said:
>> yum -y upgrade
>> And after running bootstrap, it said "autoconf" and "automake" are old
>> version. Thus I downloaded autoconf-2.68 and automake-1.11.3 from here:
>> http://www.rtems.com/ftp/pub/rtems/SOURCES/4.11/
>> and installed them.
>> Is these new instalations, makes the error?
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
More information about the rtems-users
