RTEMS on x86 PC
harryxiyou
harryxiyou at gmail.com
Wed Feb 22 06:24:01 CST 2012
On Wed, Feb 22, 2012 at 7:33 PM, Cláudio Silva <claudiodcsilva at gmail.com> wrote:
> Hi,
Hi Claudio,
> Yes you can test RTEMS in your PC. You just have to build RTEMS for
> the i386 architecture and pc386 (or later) board support package. Once
> you have a RTEMS application built you can use GRUB to boot it. (if
> you have grub already installed on your PC you just have to change the
> "kernel=" parameter to point to an RTEMS application)
> For more information on how to build RTEMS and a sample application:
> http://rtems.org/onlinedocs/doc-current/share/rtems/html/
> http://wiki.rtems.org/wiki/index.php/Quick_Start
> http://wiki.rtems.org/wiki/index.php/Example_Application_Compiling
> For more information about the boot:
> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/i386/pc386/HOWTO
> http://wiki.rtems.org/wiki/index.php/Pc386
> http://wiki.rtems.org/wiki/index.php/QEMU
I will do this. Thanks ;-)
Thanks
Harry Wei
More information about the rtems-users
