How to get the multi-lib options of a RTEMS installation
Sebastian Huber
Fri Feb 10 01:47:21 CST 2012
On 02/10/2012 04:05 AM, Ralf Corsepius wrote:
> On 02/09/2012 05:44 PM, Sebastian Huber wrote:
>> This whould be nice for building libraries which depend only
>> on POSIX interfaces.
> I don't understand this question. Are you trying to build an RTEMS with
> cpukit/posix enabled (or more general, with RTEMS cpukit specific flags
> enabled) for some multilib variants and disabled for others and are trying to
> install them into the default directories? In general, this doesn't work.
Lets suppose I have a simple library (libfancy.a) consisting of only one source
file:
#include "fancy.h"
void fancy_memcpy(const void *src, void *dst, size_t n)
memcpy(dst, src, n);
The header file for this library is:
#include <stddef.h>
void fancy_memcpy(const void *src, void *dst, size_t n);
Clearly this library doesn't depend on certain RTEMS or BSP features. Its only
dependency is the C library. Now it would be nice to build this library with
the GCC options corresponding to the libc.a in the multi-lib directories. I
want one libfancy.a in every directory containing a libc.a.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
More information about the rtems-users
