Issue in blackfin 537Stamp ticker test
Rohan Kangralkar
rohankangralkar at yahoo.com
Fri Jan 21 17:27:42 CST 2011
Hi Mike,
The core remains the same. There is slight difference in the system
interrupt mapping (and some devices). But that should not cause problem in
porting.
The issue i am facing is that the processes execute properly on the virgin
stack. But when the process try to start for their second time slice the
program crashes.
I have made some changes to the code to get to this stage. So my question is
does anyone tried executing the test programs on bfin537Stamp with
interrupts. The reason i ask this question is to identify if the 537Stamp
code was right and i am moving in wrong dorection debuging and changing the
code OR the 537Stamp code is buggy and i have to debug it or look at the 533
port.
On Fri, Jan 21, 2011 at 4:57 PM, Mike Frysinger <vapier.adi at gmail.com>wrote:
> On Fri, Jan 21, 2011 at 16:47, Rohan Kangralkar wrote:
> > I tried to execute rtems 4.9 bfin537Stamp on a 527 processor (the two
> cores
> > are similar) . When i try to execute the multi processing task(ticker
> test)
> > i see that only the first task is executed the other task is never
> executed.
> > Has anyone tried executing the ticker test on bfin537Stamp.
> i dont know what the test is doing, but wrt BF537 and BF527
> differences, the cores are exactly the same. for peripherals that
> both have, they'll be the same. but the pinmuxing will be completely
> different.
> -mike
URL: <http://www.rtems.org/pipermail/rtems-users/attachments/20110121/8fccf733/attachment.html>
More information about the rtems-users
