Can't build RTEMS-4.10 toolchain on OS X Lion
Yann Sionneau
yann at minet.net
Thu Aug 25 06:46:15 CDT 2011
On 08/25/2011 01:33 PM, Ralf Corsepius wrote:
> On 08/24/2011 06:00 PM, Ralf Corsepius wrote:
>> On 08/24/2011 05:16 PM, Eric Norum wrote:
>>> I'm also having troubles building the tool chain for RTEMS-4.10.
>> Please check the contents of this file (Likely
>> /usr/local/rtems/BuildTools/build/m68k-rtems4.10/libgcc/config.log)
> Eric sent me his config.log on PM.
> It shows his build is dying because the freshly built cross-compiler
> ICEs:
> configure:2611: /usr/local/rtems/BuildTools/build/./gcc/xgcc
> -B/usr/local/rtems/BuildTools/build/./gcc/ -nostdinc
> -B/usr/local/rtems/BuildTools/build/m68k-rtems4.10/newlib/ -isystem
> /usr/local/rtems/BuildTools/build/m68k-rtems4.10/newlib/targ-include
> -isystem /usr/local/rtems/BuildTools/gcc-4.4.5/newlib/libc/include
> -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/bin/
> -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/lib/ -isystem
> /usr/local/rtems/rtems-4.10/m68k-rtems4.10/include -isystem
> /usr/local/rtems/rtems-4.10/m68k-rtems4.10/sys-include -c -g -O2
> conftest.c >&5
> conftest.c:16: internal compiler error: in execute_ipa_pass_list, at
> passes.c:1342
> Please submit a full bug report,
> with preprocessed source if appropriate.
> See <http://gcc.gnu.org/bugs.html> for instructions.
> configure:2614: $? = 1
> configure: failed program was:
> | /* confdefs.h. */
> | #define PACKAGE_NAME "GNU C Runtime Library"
> | #define PACKAGE_TARNAME "libgcc"
> | #define PACKAGE_VERSION "1.0"
> | #define PACKAGE_STRING "GNU C Runtime Library 1.0"
> | #define PACKAGE_BUGREPORT ""
> | /* end confdefs.h. */
> | int
> | main ()
> | return 0;
> configure:2627: error: in
> `/usr/local/rtems/BuildTools/build/m68k-rtems4.10/libgcc':
> configure:2630: error: cannot compute suffix of object files: cannot
> compile
> Close to impossible for me to guess on the cause.
> Any other MacOS users out there?
> Do the rtems-4.10 toolchains build for other targets?
rtems-4.11 toolchain (lm32 one) builds fine for me under Mac OS X 10.6
(Snow leopard)
I wrote a Portfile for MacPorts to ease installation of lm32-rtems
toolchain :
http://trac.macports.org/ticket/30767
http://trac.macports.org/ticket/30766
It works for me (and enables me to generate a .dmg installation file in
one command)
The only problem I had with gcc 4.5.2 is that -arch= was passed to Apple
gcc during compilation of libgcc which is not supported and it made the
compilation fail at the exact same point in the logs posted in the
original e-mail from Eric Norum.
This issue (-arch) is fixed by the following files in the gcc Portfile :
# the generated compiler doesn't accept -arch
if {[info exists build_arch] && ${os.platform} == "darwin"} {
configure.cc_archflags
configure.cxx_archflags
configure.objc_archflags
configure.pre_args-append --build=${build_arch}-apple-darwin${os.major}
I thought it was the same issue, it seems it is not.
If I can do something or test something that can help, tell me :)
Regards,
Yann Sionneau
More information about the rtems-users
