NDS BSP patch
Mon Aug 15 01:45:47 CDT 2011
On 08/13/2011 06:35 PM, Julien Delange wrote:
> On Sat, Aug 13, 2011 at 5:43 PM, Julien Delange
> <julien.delange at gmail.com>  wrote:
>> [snip]
> I also compiled the examples of for RTEMS 4.10 and execute them on
> real hardware. It seems all tests passed successfully on the real
> hardware, using a flash card as the M3/R4.
In your previous mail you mention problems with semaphores.  Are they solved
with your patch?
> If interested, you can download examples binaries on
> http://julien.gunnm.org/public/rtems/test-executables-nds-rtems4.10.tgz
> Also, the BSP itself seems to work fine. The only thing is that I
> expected that the scheduler will reschedule some tasks when invoking
> rtems_task_wake_after (RTEMS_YIELD...) but it seems it does not work
> like that.
The yield works only within a group of threads of the same priority.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
More information about the rtems-users mailing list
