rtems++ test stub, how to compile it?
Ralf Corsepius
ralf.corsepius at rtems.org
Tue Aug 9 11:33:12 CDT 2011
On 08/09/2011 04:55 PM, Mogens Dybæk Christensen wrote:
> A lot of teststubs in i386-rtems4.10/c/testsuites are built, but not this one.
> $BUILD_DIR/rtems-4.10.0/configure --enable-rtems-debug \
> --target=$TARGET --enable-posix \
> --prefix=/opt/rtems-4.10 \
> --enable-networking --enable-cxx \
> --enable-rtemsbsp="pc386" --enable-maintainer-mode \
> --enable-tests=samples
> I have also tried enable-tests=yes. Same result.
Check the output running configure produces and check if you have your
target's g++ installed. I guess you don't have the target's g++
compiler (i386-rtems4.10-g++) installed (or it's broken).
rtems++ is only being built if building librtems++ is enabled
(--enable-cxx), --enable-tests (==--enable-tests=yes) is being passed
and if the target-toolchain's g++ is installed.
> Our build scripts are based upon a step by step description for Ubuntu on the wiki.
Well, Ubuntu ... many further possibilities.
Ralf
More information about the rtems-users
