rtems_bsdnet_do_dhcp_failsafe problems
Peter Dufault
dufault at hda.com
Tue Aug 2 09:23:22 CDT 2011
This isn't working for me, at least on PowerPC mpc55xx with smc91111.
1. The ifflags variables being passed down to rtems_bsdnet_ifconfig() are int, not int16_t or short, and so they aren't being set properly. This results in "dhcpc_failsafe: no suitable interface" since the loopback and point-to-point bits wind up being set in my situation.
2. Once I fix that it finds the interface, however, the carrier LED on the switch never comes on and it times out looking for an address:
SMC91111 : driver has been attached
starting dhcp on interface smc0
starting dhcp client...
BOOTP timeout for server 255.255.255.255
BOOTP call failed -- Connection timed out
Setting static address for interface smc0.
3. However, if I use regular-old rtems_bsdnet_do_dhcp() the LED on the switch comes on and the board gets an address (not sure about that default route error, it's working OK for my purposes, though):
dhcpc: smc: inet: 192.168.240.46 mask: 255.255.255.0
srv: 192.168.240.1 gw: 0.0.0.0
nfs_boot: del default route, error=3
Device: /dev/pty0../dev/pty7 (8)pseudo-terminals registered.
telnetd started with stacksize = 8192 and priority = 100
I think it must be something different between rtems_bsdnet_do_dhcp() and rtems_bsdnet_do_dhcp_timeout(). Does anyone know what happens that turns on the switch light and what the problem might be?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
More information about the rtems-users
