Stack full or something else?
João Rasta
freakforever at gmail.com
Mon Nov 15 14:15:44 CST 2010
Hi Gedare,
Will CONFIGURE_EXTRA_TASK_STACKS also work with the POSIX API?
Best,
JM
On Mon, Nov 15, 2010 at 6:34 PM, Gedare Bloom <gedare at gwmail.gwu.edu> wrote:
> João,
> You can configure extra space for all of your tasks like this:
> #define CONFIGURE_EXTRA_TASK_STACKS (RTEMS_MINIMUM_STACK_SIZE * ??)
> Where you put ?? to make it a multiple of min stack size, or you can just
> put an arbitrary number of bytes.
> Otherwise you can increase the stack_size argument to rtems_task_create for
> a particular task.
> You might also try configuring with CONFIGURE_STACK_CHECKER_ENABLED
> defined. It does some extra checks for stack bounds and might give you a
> tighter window for debugging where the problem is occurring.
> -Gedare
> On Mon, Nov 15, 2010 at 1:13 PM, João Rasta <freakforever at gmail.com>wrote:
>> Hi Joel,
>> Good point. I have a task that is heavy on memory operations (multi-size
>> array operations and so on). It also has a lot of doubles so it can also be
>> corrupting its stack. Too bad it is 'silent' when corrupting the memory one
>> way or another..
>> To eliminate the stack overflow issue, i guess it is not enough to
>> increase the initial task stack size. Is there a way to control the
>> subsequent called task stack sizes?
>> Best,
>> JM
>> On Mon, Nov 15, 2010 at 5:43 PM, Joel Sherrill <joel.sherrill at oarcorp.com
>> > wrote:
>>> On 11/15/2010 11:24 AM, João Rasta wrote:
>>>> After some hard debuggin' with gdb i found out that this error is
>>>> occurring at _Semaphore_Translate_core_mutex_return_code() but i still don't
>>>> know why it happens. Here's the disassembly of the code where the error is
>>>> generated
>>>> 0x40040d88 <rtems_semaphore_obtain+192>: ld [ %l3 ], %g1
>>>> 0x40040d8c <rtems_semaphore_obtain+196>: call 0x400410c8
>>>> <_Semaphore_Translate_core_mutex_return_code>
>>>> 0x40040d90 <rtems_semaphore_obtain+200>: ld [ %g1 + 0x34 ], %o0
>>>> 0x40040e20 <rtems_semaphore_obtain+344>: b 0x40040d8c
>>>> 0x40040e24 <rtems_semaphore_obtain+348>: ld [ %l3 ], %g1
>>>> 0x40040ed8 <rtems_semaphore_obtain+528>: b 0x40040d8c
>>>> 0x40040edc <rtems_semaphore_obtain+532>: ld [ %l3 ], %g1
>>>> And Stack copy:
>>>> Thread [3] (Suspended: Signal 'SIGSEGV' received. Description:
>>>> Segmentation fault.)
>>>> 3 rtems_semaphore_obtain()
>>>> c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\rtems\src\semobtain.c:90
>>>> 0x40040edc
>>>> 2 <symbol is not available> 0x00000008
>>>> 1 <symbol is not available> 0x0000000c
>>>> If this is the backtrace, somehow the stack pointer has gotten
>>> corrupted.
>>> The last value i could get from %g1 is 0.
>>> If this task is not blowing its stack, then we are left with a couple
>>> of guesses:
>>> + another task is blowing its stack and corrupting memory
>>> that impacts this task.
>>> + stray write is corrupting something.
>>> When did you see the %g1 have 0? What was the last instruction?
>>> Where was it loading from?
>>> Here's how i'm configuring semaphores:
>>>> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 15
>>>> This only affects POSIX semaphores sem_XXX.
>>>> Any hints on what it can be failing? Should i set
>>>> CONFIGURE_MAXIMUM_SEMAPHORES as well?
>>>> I doubt it since you appear to be completing a semaphore_obtain.
>>> That means (probably) that a semaphore_create worked.
>>> Do a backtrace in gdb. I suspect you will find you are coming from a
>>> subsystem
>>> like termios.
>>> -joel
>>>> Best,
>>>> JM
>>>> On Fri, Nov 12, 2010 at 7:34 PM, Joel Sherrill <
>>>> joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>>>> On 11/12/2010 01:05 PM, João Rasta wrote:
>>>> Hi Daron,
>>>> It is running on a LEON-3. The application exits raising the
>>>> following exception:
>>>> IU in error mode (tt = 0x07)
>>>> which is a memory access to an unaligned address. The last
>>>> instruction is this:
>>>> 4003bd74 d0006034 ld [%g1 + 0x34], %o0
>>>> What is the value of g1? Is it unaligned?
>>>> I don't understand why i have this error. The code where this
>>>> error is being reported is compiled independently and then put
>>>> in a library, but it uses the same cross-compiler as the main
>>>> source code. I don't think i'm doing something wrong while
>>>> compiling the library files, i use the same compilation flags..
>>>> What can i be missing to have unaligned memory accesses?
>>>> Best,
>>>> JM
>>>> On Fri, Nov 12, 2010 at 6:43 PM, Daron Chabot
>>>> <daron.chabot at gmail.com <mailto:daron.chabot at gmail.com>
>>>> <mailto:daron.chabot at gmail.com>>> wrote:
>>>> On Fri, Nov 12, 2010 at 11:50 AM, João Rasta
>>>> <freakforever at gmail.com <mailto:freakforever at gmail.com>
>>>> <mailto:freakforever at gmail.com>>> wrote:
>>>> Hi,
>>>> I have an RTEMS POSIX API application which comes to a
>>>> point
>>>> that if a small function (with some doubles passed as
>>>> arguments) is called, the application exits with an
>>>> error. At
>>>> first i thought of increasing the stack space. I did
>>>> this with
>>>> CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE but the problem
>>>> remains
>>>> even if i remove all the contents of the function.
>>>> 1) Am i setting up the stack size correctly? I think i
>>>> am, but
>>>> i ask just in case..
>>>> 2) Is there any other explanation to why a function call
>>>> crashes the application besides having a full stack?
>>>> Again, i
>>>> erased the function contents..
>>>> What architecture is this running on ?
>>>> What is the application exit error (message and/or return
>>>> code)?
>>>> It looks like all POSIX threads are created as floating-point
>>>> tasks (FP state saved across context switches), so there
>>>> "shouldn't" be a problem on that aspect...
>>>> Best,
>>>> JM
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>>> <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>> -- Joel Sherrill, Ph.D. Director of Research&
>>>> Development
>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>> Support Available (256) 722-9985
>>> Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://www.rtems.org/pipermail/rtems-users/attachments/20101115/aac9048b/attachment.html>
More information about the rtems-users
