Stack full or something else?
Gedare Bloom
gedare at gwmail.gwu.edu
Mon Nov 15 12:34:31 CST 2010
João,
You can configure extra space for all of your tasks like this:
#define CONFIGURE_EXTRA_TASK_STACKS (RTEMS_MINIMUM_STACK_SIZE * ??)
Where you put ?? to make it a multiple of min stack size, or you can just
put an arbitrary number of bytes.
Otherwise you can increase the stack_size argument to rtems_task_create for
a particular task.
You might also try configuring with CONFIGURE_STACK_CHECKER_ENABLED
defined. It does some extra checks for stack bounds and might give you a
tighter window for debugging where the problem is occurring.
-Gedare
On Mon, Nov 15, 2010 at 1:13 PM, João Rasta <freakforever at gmail.com> wrote:
> Hi Joel,
> Good point. I have a task that is heavy on memory operations (multi-size
> array operations and so on). It also has a lot of doubles so it can also be
> corrupting its stack. Too bad it is 'silent' when corrupting the memory one
> way or another..
> To eliminate the stack overflow issue, i guess it is not enough to increase
> the initial task stack size. Is there a way to control the subsequent called
> task stack sizes?
> Best,
> JM
> On Mon, Nov 15, 2010 at 5:43 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
>> On 11/15/2010 11:24 AM, João Rasta wrote:
>>> After some hard debuggin' with gdb i found out that this error is
>>> occurring at _Semaphore_Translate_core_mutex_return_code() but i still don't
>>> know why it happens. Here's the disassembly of the code where the error is
>>> generated
>>> 0x40040d88 <rtems_semaphore_obtain+192>: ld [ %l3 ], %g1
>>> 0x40040d8c <rtems_semaphore_obtain+196>: call 0x400410c8
>>> <_Semaphore_Translate_core_mutex_return_code>
>>> 0x40040d90 <rtems_semaphore_obtain+200>: ld [ %g1 + 0x34 ], %o0
>>> 0x40040e20 <rtems_semaphore_obtain+344>: b 0x40040d8c
>>> 0x40040e24 <rtems_semaphore_obtain+348>: ld [ %l3 ], %g1
>>> 0x40040ed8 <rtems_semaphore_obtain+528>: b 0x40040d8c
>>> 0x40040edc <rtems_semaphore_obtain+532>: ld [ %l3 ], %g1
>>> And Stack copy:
>>> Thread [3] (Suspended: Signal 'SIGSEGV' received. Description:
>>> Segmentation fault.)
>>> 3 rtems_semaphore_obtain()
>>> c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\rtems\src\semobtain.c:90
>>> 0x40040edc
>>> 2 <symbol is not available> 0x00000008
>>> 1 <symbol is not available> 0x0000000c
>>> If this is the backtrace, somehow the stack pointer has gotten
>> corrupted.
>> The last value i could get from %g1 is 0.
>> If this task is not blowing its stack, then we are left with a couple
>> of guesses:
>> + another task is blowing its stack and corrupting memory
>> that impacts this task.
>> + stray write is corrupting something.
>> When did you see the %g1 have 0? What was the last instruction?
>> Where was it loading from?
>> Here's how i'm configuring semaphores:
>>> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 15
>>> This only affects POSIX semaphores sem_XXX.
>>> Any hints on what it can be failing? Should i set
>>> CONFIGURE_MAXIMUM_SEMAPHORES as well?
>>> I doubt it since you appear to be completing a semaphore_obtain.
>> That means (probably) that a semaphore_create worked.
>> Do a backtrace in gdb. I suspect you will find you are coming from a
>> subsystem
>> like termios.
>> -joel
>>> Best,
>>> JM
>>> On Fri, Nov 12, 2010 at 7:34 PM, Joel Sherrill <
>>> joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>>> On 11/12/2010 01:05 PM, João Rasta wrote:
>>> Hi Daron,
>>> It is running on a LEON-3. The application exits raising the
>>> following exception:
>>> IU in error mode (tt = 0x07)
>>> which is a memory access to an unaligned address. The last
>>> instruction is this:
>>> 4003bd74 d0006034 ld [%g1 + 0x34], %o0
>>> What is the value of g1? Is it unaligned?
>>> I don't understand why i have this error. The code where this
>>> error is being reported is compiled independently and then put
>>> in a library, but it uses the same cross-compiler as the main
>>> source code. I don't think i'm doing something wrong while
>>> compiling the library files, i use the same compilation flags..
>>> What can i be missing to have unaligned memory accesses?
>>> Best,
>>> JM
>>> On Fri, Nov 12, 2010 at 6:43 PM, Daron Chabot
>>> <daron.chabot at gmail.com <mailto:daron.chabot at gmail.com>
>>> <mailto:daron.chabot at gmail.com>>> wrote:
>>> On Fri, Nov 12, 2010 at 11:50 AM, João Rasta
>>> <freakforever at gmail.com <mailto:freakforever at gmail.com>
>>> <mailto:freakforever at gmail.com>>> wrote:
>>> Hi,
>>> I have an RTEMS POSIX API application which comes to a
>>> point
>>> that if a small function (with some doubles passed as
>>> arguments) is called, the application exits with an
>>> error. At
>>> first i thought of increasing the stack space. I did
>>> this with
>>> CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE but the problem
>>> remains
>>> even if i remove all the contents of the function.
>>> 1) Am i setting up the stack size correctly? I think i
>>> am, but
>>> i ask just in case..
>>> 2) Is there any other explanation to why a function call
>>> crashes the application besides having a full stack?
>>> Again, i
>>> erased the function contents..
>>> What architecture is this running on ?
>>> What is the application exit error (message and/or return
>>> code)?
>>> It looks like all POSIX threads are created as floating-point
>>> tasks (FP state saved across context switches), so there
>>> "shouldn't" be a problem on that aspect...
>>> Best,
>>> JM
>>> rtems-users mailing list
>>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>> <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>> -- Joel Sherrill, Ph.D. Director of Research&
>>> Development
>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>> Support Available (256) 722-9985
>> Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://www.rtems.org/pipermail/rtems-users/attachments/20101115/376798ee/attachment.html>
More information about the rtems-users
