Stack full or something else?
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Nov 15 11:43:16 CST 2010
On 11/15/2010 11:24 AM, João Rasta wrote:
> After some hard debuggin' with gdb i found out that this error is
> occurring at _Semaphore_Translate_core_mutex_return_code() but i still
> don't know why it happens. Here's the disassembly of the code where
> the error is generated
> 0x40040d88 <rtems_semaphore_obtain+192>: ld [ %l3 ], %g1
> 0x40040d8c <rtems_semaphore_obtain+196>: call 0x400410c8
> <_Semaphore_Translate_core_mutex_return_code>
> 0x40040d90 <rtems_semaphore_obtain+200>: ld [ %g1 + 0x34 ], %o0
> 0x40040e20 <rtems_semaphore_obtain+344>: b 0x40040d8c
> 0x40040e24 <rtems_semaphore_obtain+348>: ld [ %l3 ], %g1
> 0x40040ed8 <rtems_semaphore_obtain+528>: b 0x40040d8c
> 0x40040edc <rtems_semaphore_obtain+532>: ld [ %l3 ], %g1
> And Stack copy:
> Thread [3] (Suspended: Signal 'SIGSEGV' received. Description:
> Segmentation fault.)
> 3 rtems_semaphore_obtain()
> c:\opt\rtems-4.10-mingw\src\rtems-4.10\cpukit\rtems\src\semobtain.c:90
> 0x40040edc
> 2 <symbol is not available> 0x00000008
> 1 <symbol is not available> 0x0000000c
If this is the backtrace, somehow the stack pointer has gotten
corrupted.
> The last value i could get from %g1 is 0.
If this task is not blowing its stack, then we are left with a couple
of guesses:
+ another task is blowing its stack and corrupting memory
that impacts this task.
+ stray write is corrupting something.
When did you see the %g1 have 0? What was the last instruction?
Where was it loading from?
> Here's how i'm configuring semaphores:
> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 15
This only affects POSIX semaphores sem_XXX.
> Any hints on what it can be failing? Should i set
> CONFIGURE_MAXIMUM_SEMAPHORES as well?
I doubt it since you appear to be completing a semaphore_obtain.
That means (probably) that a semaphore_create worked.
Do a backtrace in gdb. I suspect you will find you are coming from a
subsystem
like termios.
-joel
> Best,
> JM
> On Fri, Nov 12, 2010 at 7:34 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
> On 11/12/2010 01:05 PM, João Rasta wrote:
> Hi Daron,
> It is running on a LEON-3. The application exits raising the
> following exception:
> IU in error mode (tt = 0x07)
> which is a memory access to an unaligned address. The last
> instruction is this:
> 4003bd74 d0006034 ld [%g1 + 0x34], %o0
> What is the value of g1? Is it unaligned?
> I don't understand why i have this error. The code where this
> error is being reported is compiled independently and then put
> in a library, but it uses the same cross-compiler as the main
> source code. I don't think i'm doing something wrong while
> compiling the library files, i use the same compilation flags..
> What can i be missing to have unaligned memory accesses?
> Best,
> JM
> On Fri, Nov 12, 2010 at 6:43 PM, Daron Chabot
> <daron.chabot at gmail.com <mailto:daron.chabot at gmail.com>
> <mailto:daron.chabot at gmail.com>>> wrote:
> On Fri, Nov 12, 2010 at 11:50 AM, João Rasta
> <freakforever at gmail.com <mailto:freakforever at gmail.com>
> <mailto:freakforever at gmail.com>>> wrote:
> Hi,
> I have an RTEMS POSIX API application which comes to a
> point
> that if a small function (with some doubles passed as
> arguments) is called, the application exits with an
> error. At
> first i thought of increasing the stack space. I did
> this with
> CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE but the problem
> remains
> even if i remove all the contents of the function.
> 1) Am i setting up the stack size correctly? I think i
> am, but
> i ask just in case..
> 2) Is there any other explanation to why a function call
> crashes the application besides having a full stack?
> Again, i
> erased the function contents..
> What architecture is this running on ?
> What is the application exit error (message and/or return
> code)?
> It looks like all POSIX threads are created as floating-point
> tasks (FP state saved across context switches), so there
> "shouldn't" be a problem on that aspect...
> Best,
> JM
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> <mailto:rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
More information about the rtems-users
