Still unable to build RTEMS 4.10 for PowerPC under WIN32
Chris Johns
chrisj at rtems.org
Mon Nov 8 15:24:42 CST 2010
On 9/11/10 6:13 AM, Sam Lost wrote:
> I have successfully been able to build the 4.10 psim and mcp750 BSP's,
> many thanks to everyone that helped, especially Chris, Alan and
> Sebastian. The problem appears to be how the files were extracted from
> CVS, I used tortoise CVS using the UNIX file ending option. I have now
> extracted the files from CVS using the MinGW command line, I have been
> able to run bootstrap and build the psim and mcp750 BSP's.
Well done on getting a working RTEMS.
I have not been able to get the command line CVS to work in MinGW. Did
you need to do anything special ?
More information about the rtems-users
