rtems kernel
Karel Gardas
karel.gardas at centrum.cz
Mon Nov 8 05:53:54 CST 2010
Hi,
RTEMS kernel is linked directly into application executable. Just boot
any of the exe files below and you will get what you are searching for.
Cheers,
Karel
On 11/08/10 12:44, Eugene Shvets wrote:
> I need to boot rtems with GRUB.
> There are wiki pages devoted to QEMU and GRUB. However I need a kernel image
> of rtems to use grub(like when we use linux, we put linux-kernel-2.6.xy into
> /boot directory). I cannot find it.
> I did some search and found the same question
> http://www.rtems.com/ml/rtems-users/2008/february/msg00125.html
> So, I installed rtems as said in here
> http://www.rtems.com/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu
> However I couldn't find the image or nesessary *.exe file.
> I invoked :/opt/rtems-4.10# find . -name "*.exe" -print
> And got the following result:
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/pppd.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/cxx_iostream.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/paranoia.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/fileio.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/capture.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/base_sp.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/minimum.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/cdtest.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/unlimited.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/nsecs.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/ticker.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/loopback.exe
> ./bfin-rtems4.10/bf537Stamp/lib/rtems-4.11/tests/hello.exe
> Why these samples are stored at lib directory?
> And where is the RTEMS image ? What is it named like? how can I search it?
> Thank you
> rtems-users mailing list
> rtems-users at rtems.org
More information about the rtems-users
