Still unable to build RTEMS 4.10 for PowerPC under WIN32
Sam Lost
slostuk at gmail.com
Thu Nov 4 11:16:17 CDT 2010
After reading and re-reading the directions given, I am still unable to
build RTEMS 4.10 for PowerPC under WIN32.
I installed on a clean PC MinGW, MinSys, and replaced M4 version as
directed.
when I run bootstrap I get the following error:
/usr/bin/m4: unrecognized option `--gnu'
Command History of lastest attempt
$ history
1 which perl
2 cd /
3 pwd
4 ls
5 cd /c
6 ls
7 tar -xvf /e/rtems-root/rtems-4.10-powerpc-rtems4.10-binutils-2.20.1-3.ta
.bz2
8 tar -xvf /e/rtems-root/rtems-4.10-powerpc-rtems4.10-gcc-4.4.5-2.tar.bz2
9 tar -xvf /e/rtems-root/rtems-4.10-powerpc-rtems4.10-gcc-c++-4.4.5-2.tar.
z2
10 tar -xvf /e/rtems-root/rtems-4.10-powerpc-rtems4.10-gcc-libgcc-4.4.5-2.t
r.bz2
11 tar -xvf /e/rtems-root/rtems-4.10-powerpc-rtems4.10-gcc-libstdc++-4.4.5-
.tar.bz2
12 tar -xvf /e/rtems-root/rtems-4.10-powerpc-rtems4.10-newlib-1.18.0-17.tar
bz2
13 tar -xvf /e/rtems-root/rtems-4.10-autoconf-2.68-1.tar.bz2
14 tar -xvf /e/rtems-root/rtems-4.10-automake-1.11.1-2.tar.bz2
15 cd RTEMS-4.10-Build/
16 ls
17 cd rtems/
18 export PATH=/opt/rtems-4.10/bin:$PATH
19 ./bootstrap
20 ./bootstrap -c
21 m4 --version
22 history
Any ideas why I am still unable to run bootstrap?
Regards
Sam
URL: <http://www.rtems.org/pipermail/rtems-users/attachments/20101104/6bbaa514/attachment.html>
More information about the rtems-users
