Strange behavior in SNMP / UDP Code
Paul Whitfield
paulw at omnitronics.com.au
Mon Nov 1 02:36:26 CDT 2010
Hi All,
I have seen some strange behaviour with the snmp code and the
network stack and I was wondering if anyone can shed some light on it.
In the SNMP code that is meant to list the current UDP sessions
a sysctl call is made (simplified code) as shown
int sname[] =
{ CTL_NET, PF_INET, IPPROTO_UDP, UDPCTL_PCBLIST };
if (sysctl(sname, 4, 0, &len, 0, 0) < 0) {
return;
However, the length returned is negative, causing subsequent
code to fail.
Looking at the internals of the network code,
I tracked this back to a negative value in the
the function
udp_pcblist
It does the following calculation, and the value of udbinfo.ipi_count
is negative.
n = udbinfo.ipi_count;
req->oldidx = 2 * (sizeof xig)
+ (n + n/8) * sizeof(struct xinpcb);
Firstly: I am using an old version of rtems (4.6.6) and so this may
be a problem that has been fixed, however I could not see any
evidence of this in the history of udp_userreq.c
Regards
Paul
*** YES I know I need to update to a more current version of RTEMS,
it is at the top of my todo list, and has been for a very long time.
Regards
Paul Whitfield
Software Engineer
27 Sarich Court, Osborne Park
Perth WA 6017
P: +61 8 9445 2633
F: +61 8 9445 1687
I: www.omnitronics.com.au <http://www.omnitronics.com.au>
Please consider the environment before printing this email.
This message and any attachment are confidential. If you are not the
intended recipient, please telephone or email the sender and delete the
message and any attachment from your system. If you are not the intended
recipient you must not copy this message or attachment or disclose the
contents to any other person.
Message protected by MailGuard: e-mail anti-virus, anti-spam and content filtering.http://www.mailguard.com.au/mg
More information about the rtems-users
