Problem with rtems-ttcp example
Luis Mollinedo Herrera
lmollinedo at gmv.com
Thu Feb 18 13:48:38 CST 2010
Hello,
I'm trying to get to work the "rtems-ttcp" example with a GR-PCI-XC2V (LEON3) board with no success. This is the networkconfig.h file:
* Network configuration
* EDIT THIS FILE TO REFLECT YOUR NETWORK CONFIGURATION *
* BEFORE RUNNING ANY RTEMS PROGRAMS WHICH USE THE NETWORK! *
* networkconfig.h,v 1.8 2001/08/31 18:11:43 joel Exp
#ifndef _RTEMS_NETWORKCONFIG_H_
#define _RTEMS_NETWORKCONFIG_H_
#include <network_interface_add.h>
/* #define RTEMS_USE_BOOTP */
/* #include <bsp.h> */
#ifdef RTEMS_USE_LOOPBACK
* Loopback interface
extern void rtems_bsdnet_loopattach();
static struct rtems_bsdnet_ifconfig loopback_config = {
"lo0", /* name */
rtems_bsdnet_loopattach, /* attach function */
NULL, /* link to next interface */
"127.0.0.1", /* IP address */
"255.0.0.0", /* IP net mask */
#endif
struct rtems_bsdnet_config rtems_bsdnet_config = {
&loopback_config, /* link to next interface */
#else
NULL, /* No more interfaces */
#endif
#if (defined (RTEMS_USE_BOOTP))
rtems_bsdnet_do_bootp,
#else
NULL,
#endif
100, /* Default network task priority */
128*1024, /* Default mbuf capacity */
256*1024, /* Default mbuf cluster capacity */
#if (!defined (RTEMS_USE_BOOTP))
"rtems_host", /* Host name */
"localnet", /* Domain name */
"192.168.0.1", /* Gateway */
"192.168.0.1", /* Log host */
{"192.168.0.1" }, /* Name server(s) */
{"192.168.0.1" }, /* NTP server(s) */
#endif /* !RTEMS_USE_BOOTP */
/* Table used by network interfaces that register themselves using the
* network_interface_add routine. From this table the IP address, netmask
* and Ethernet MAC address of an interface is taken.
* The network_interface_add routine puts the interface into the
* rtems_bsnet_config.ifconfig list.
* Set IP Address and Netmask to NULL to select BOOTP.
struct ethernet_config interface_configs[] =
{ "192.168.0.66", "255.255.255.0", {0x00, 0x80, 0x7F, 0x22, 0x61, 0x79}},
{ "192.168.1.66", "255.255.255.0", {0x00, 0x80, 0x7F, 0x22, 0x61, 0x7A}},
{ "192.168.2.66", "255.255.255.0", {0x00, 0x80, 0x7F, 0x22, 0x61, 0x7B}},
{ "192.168.3.66", "255.255.255.0", {0x00, 0x80, 0x7F, 0x22, 0x61, 0x7C}},
{ "192.168.4.66", "255.255.255.0", {0x00, 0x80, 0x7F, 0x22, 0x61, 0x7D}},
{ "192.168.5.66", "255.255.255.0", {0x00, 0x80, 0x7F, 0x22, 0x61, 0x7E}},
{ "192.168.6.66", "255.255.255.0", {0x00, 0x80, 0x7F, 0x22, 0x61, 0x7F}},
{NULL, NULL, {0,0,0,0,0,0}}
#define INTERFACE_CONFIG_CNT (sizeof(interface_configs)/sizeof(struct ethernet_config) - 1)
* For TFTP test application
#define RTEMS_TFTP_TEST_HOST_NAME "BOOTP_HOST"
#define RTEMS_TFTP_TEST_FILE_NAME "BOOTP_FILE"
#else
#define RTEMS_TFTP_TEST_HOST_NAME "XXX.YYY.ZZZ.XYZ"
#define RTEMS_TFTP_TEST_FILE_NAME "tftptest"
#endif
#endif /* _RTEMS_NETWORKCONFIG_H_ */
This is the grmon output:
C:\opt\rtems-4.10-mingw\src\samples>grmon-eval -nosram -u
GRMON LEON debug monitor v1.1.38 evaluation version
Copyright (C) 2004-2008 Aeroflex Gaisler - all rights reserved.
For latest updates, go to http://www.gaisler.com/
Comments or bug-reports to support at ...
This evaluation version will expire on 21/9/2010
try open device //./com1
###opened device //./com1
initialising .............
detected frequency: 40 MHz
Component Vendor
LEON3 SPARC V8 Processor Gaisler Research
AHB Debug UART Gaisler Research
AHB Debug JTAG TAP Gaisler Research
Simple 32-bit PCI Target Gaisler Research
GR Ethernet MAC Gaisler Research
LEON2 Memory Controller European Space Agency
AHB/APB Bridge Gaisler Research
LEON3 Debug Support Unit Gaisler Research
Generic APB UART Gaisler Research
Multi-processor Interrupt Ctrl Gaisler Research
Modular Timer Unit Gaisler Research
General purpose I/O port Gaisler Research
Use command 'info sys' to print a detailed report of attached cores
grlib> load rtems-ttcp
section: .text at 0x40000000, size 390128 bytes
section: .data at 0x4005f3f0, size 10208 bytes
section: .jcr at 0x40061bd0, size 4 bytes
total size: 400340 bytes (88.3 kbit/s)
read 1657 symbols
entry point: 0x40000000
grlib> verify rtems-ttcp
total size: 400340 bytes (79.8 kbit/s)
grlib> run
Initializing manager
Initializing network
greth: driver attached
**** PHY ****
Vendor: 4de Device: e Revision: 2
Current Operating Mode: 100 Mbit Half Duplex
Autonegotiation Time: 1796ms
Initializing network DONE
Destination Gateway/Mask/Hw Flags Refs Use Expire Interface
default 192.168.0.1 UGS 0 0 0 gr_eth1
192.168.0.0 255.255.255.0 U 0 0 3 gr_eth1
192.168.0.1 UHL 1 0 3 gr_eth1
************ INTERFACE STATISTICS ************
***** gr_eth1 *****
Ethernet Address: 00:80:7F:22:61:79
Address:192.168.0.66 Broadcast Address:192.168.0.255 Net mask:255.255.255.0
Flags: Up Broadcast Running Simplex
Send queue limit:50 length:0 Dropped:0
Rx Interrupts:1 Rx Packets:0 Length:0
Non-octet:0
Bad CRC:0 Overrun:0 Tx Interrupts:0
Maximal Frags:1 GBIT MAC:0
>>>ctpt t t
And this is the output from the computer with ttcp program installed:
[root at localhost rtems123]# ping 192.168.0.66
PING 192.168.0.66 (192.168.0.66) 56(84) bytes of data.
64 bytes from 192.168.0.66: icmp_seq=1 ttl=255 time=0.426 ms
64 bytes from 192.168.0.66: icmp_seq=2 ttl=255 time=0.523 ms
^C
--- 192.168.0.66 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1444ms
[root at localhost rtems123]# ttcp 192.168.0.66 -s -t bigfile
ttcp-t: buflen=8192, nbuf=2048, align=16384/0, port=5001 tcp -> 192.168.0.66
ttcp-t: socket
ttcp-t: connect: Connection refused
errno=111
I hope someone could help me with this problem.
Thanks in advance and sorry for the inconveniences.
Best regards,
Luis Mollinedo
______________________
This message including any attachments may contain confidential
information, according to our Information Security Management System,
and intended solely for a specific individual to whom they are addressed.
Any unauthorised copy, disclosure or distribution of this message
is strictly forbidden. If you have received this transmission in error,
please notify the sender immediately and delete it.
Este mensaje, y en su caso, cualquier fichero anexo al mismo,
puede contener informacion clasificada por su emisor como confidencial
en el marco de su Sistema de Gestion de Seguridad de la
Informacion siendo para uso exclusivo del destinatario, quedando
prohibida su divulgacion copia o distribucion a terceros sin la
autorizacion expresa del remitente. Si Vd. ha recibido este mensaje
erroneamente, se ruega lo notifique al remitente y proceda a su borrado.
Gracias por su colaboracion.
More information about the rtems-users
