Cross-debugging with sparc-rtems4.10-gdb, from inside Eclipse
Mauro Lacy
mlacy at invap.com.ar
Tue Feb 16 14:50:49 CST 2010
Hi.
For completeness' sake:
Mauro Lacy wrote:
> - Created a ~/.gdbinit containing:
> target sim
> load ~/workspace/HelloDebug/RTEMS\ Executable\ Configuration/a.exe #
> this is wired at the moment.
"load" without arguments loads the executable passed on the command line.
> Some actual problems I'm having:
> - The app path is wired in the .gdbinit file. Can environment
> variables be used in .gdbinit?
Not needed.
> - The debugger startup is slow. 30 seconds, or more. Seems like
> eclipse is waiting for an specific output from gdb that never comes,
> and a timeout is reached.
Fixed changing the "Debugger timeout" and "Launch timeout" parameters
under Preferences -> Debug -> GDB MI.
> - It's necessary to press a key in the console window at the moment,
> for the debugging to start. Maybe just a missing directive in ~/.gdbinit?
> - "Watch expression" doesn't seem to be working. The expressions
> always return zero...
Automatic variables are optimized into registers. Compile without
optimization (-O0) , use 'volatile' for the variable declaration, and/or
view cpu registers.
Regards,
Mauro
> - The console output gets some peformance and/or statistics output, that
> is mixed with the program output. This is probably an option of gdb.
> By the way, gdb is being called with these arguments:
> /opt/rtems-4.10/bin/sparc-rtems4.10-gdb -q -nw -i mi
> --cd=/home/dev/workspace/HelloDebug --command=~/.gdbinit
> /home/dev/workspace/HelloDebug/RTEMS Executable Configuration/a.exe
> If you have some suggestions or documentation on how to improve this,
> I would like to know about it.
> Best regards,
> Mauro
> rtems-users mailing list
> rtems-users at rtems.org
More information about the rtems-users
