Interrupt Problems (again).
Fri Feb 12 12:19:18 CST 2010
On 02/12/2010 11:55 AM, Gedare Bloom wrote:
> I haven't been using RTEMS that long, so I don't have much advice for
> you, but I did have one thought to share.
> Perhaps something strange is going on with a CPU dependent
> implementation of _ISR_Is_in_progress. Try this:
>   >  cd ${RTEMS}/cpukit/score/cpu/powerpc/rtems
>   >  grep -r CPU_PROVIDES_ISR_IS_IN_PROGRESS *
> If you get back something that says TRUE, that gives you something
> else to look for. score relies on _ISR_Nest_level to determine whether
> or not an interrupt is happening, but I suppose a mismatch between
> _ISR_Nest_level and the result of rtems_interrupt_is_in_progress()
> could be caused by a port that provides an alternate implementation of
> AFAIK there aren't any ports that actually use this option in the
> current release...
The PowerPC has kept the level in a register and since old
RTEMS PowerPC had BSP specific interrupt entry
and exit code, it could be incorrect in a BSP specific way.
2003-07-18      Till Straumann <strauman at slac.stanford.edu>
         PR 288/rtems
         * rtems/new-exceptions/cpu.h: _ISR_Nest_level is now properly
         maintained and does not reside in SPRG0.
I would be suspicious of your .S code that is CPU model or
BSP specific.
--joel
> -Gedare
> On Fri, Feb 12, 2010 at 11:47 AM, Nick Thomas<nick.thomas at pixsan.com>  wrote:
>> Hi,
>> I am still having problems with interrupts.
>> I reported a while ago that rtems_interrupt_is_in_progress() was returning
>> the wrong value occasionally.
>> Now, I see that I am getting an error 18 (RTEMS_CALLED_FROM_ISR) at a place
>> in the code that definitely back-traces to a task!
>> At the point of the crash I see that _ISR_Nest_level is zero, and
>> _Thread_Dispatch_disable_level is 1 .
>> I am using RTEMS 4.7.1 on a PowerPC 405, if that helps.
>> I know that RTEMS 4.7.1 is quite old now, but I don't realistically have the
>> ability to upgrade at this point in the project.
>> Any help/comments/suggestions welcomed.
>> Regards
>> Nick
>> Nick Thomas
>> Email: nick.thomas at pixsan.com
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D.             Director of Research&  Development
More information about the rtems-users mailing list
