zero_copy in RTEMS
Till Straumann
strauman at slac.stanford.edu
Wed Feb 10 08:05:56 CST 2010
FYI
The NFS client (libfs/src/nfsclient/) uses a similar trick to avoid
at least one copy step (could probably be further optimized).
Normally, the code would have to do two copy operations:
user code calls write();
NFS XDR-encodes user data into memory buffer, calls 'sendto'
TCP/IP stack copies XDR memory buffer into mbufs
use code calls 'read()'
recvfrom copies from mbufs into XDR buffer
nfsclient XDR-decodes from XDR buffer into user buffer.
The nfsclient avoids one of each of these steps:
NFS XDR-encodes into buffer, points mbuf to buffer and hands
mbuf to TCP/IP stack (sosend())
user code calls read();
NFS receives mbufs from TCP/IP stack (soreceive()), XDR-decodes
out of mbufs into user buffer.
Since XDR-encoding the 'write' payload is a trivial copy operation the
'write()' could be further improved by XDR-encoding header information
into mbufs and pointing a final mbuf to the user buffer, then handing the
chain to the TCP/IP stack.
Since the user always wants to 'read' into her own buffer
at least one copy step is always required when read()ing.
-- Till
Lu Chih Wen wrote:
> Hello all
> I have an idea about the implementation of zero-copy on RTEMS’s TCP/IP
> stack.
> The major concept about zero-copy is decrease the copy time of
> mbuf->m_data to application’s buffer,
> So I try to allocate mbuf chain in application and swap the appended
> cluster buffer between protocol
> and application in socket layer. I have implemented in my test
> platform and got a lot of increase of performance/
> Was anyone did this before? I hope someone can point out more detail
> that I should aware of .
> RX sequence!
> MAC HW fill driver’s allocated mbuf->m_data(Cluster buffer ) -> TCP/IP
> -> swap cluster buffer in socket layer à return to Application.
> TX sequence!
> Application fill the data in mbuf->m_data(Cluster buffer ) -> Swap
> cluster buffer in socket layer -> TCP/IP -à MAC driver.
> Yours sincerely
> Rudolph.Lu
> rtems-users mailing list
> rtems-users at rtems.org
More information about the rtems-users
