Possible error in coremutex.c
Manuel Coutinho
manuel.coutinho at edisoft.pt
Mon May 18 11:08:05 CDT 2009
Sorry...dont have test for this :(
Was just copying that code (strict order mutex) to our version and though
that could be an error...
Thank you for correcting the code so fast :)
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Monday, May 18, 2009 3:52 PM
> To: Manuel Coutinho
> Cc: 'Chris Johns'; rtems-users at rtems.com
> Subject: Re: Possible error in coremutex.c
> Manuel Coutinho wrote:
> > Hi
> > Joel, that was the change was thinking about (just add the brackets).
> PR1412/cpukit closed. :)
> Did you have a test case to demonstrate this error? It would
> be nice to get one.
> --joel
> > Kind regards
> > Manuel Coutinho
> >> From: Chris Johns [mailto:chrisj at rtems.org]
> >> Sent: Saturday, May 16, 2009 11:55 AM
> >> To: Joel Sherrill
> >> Cc: Manuel Coutinho; rtems-users at rtems.com
> >> Joel Sherrill wrote:
> >>> If so, my reading of the code agrees with you. I would like to hear
> >>> the opinion of others.
> >> This looks correct to me. I wonder if this could explain the problems I
> >> had last year when doing the libblock changes and I had the problem
> with
> >> IDLE being changed in priority. Wish I could remember the issue I had.
> >> Regards
> >> Chris
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
More information about the rtems-users
