RTEMS-mvme5500 BSP update
Kate Feng
feng1 at bnl.gov
Thu Mar 19 13:35:43 CDT 2009
Joel Sherrill wrote:
> Any chance of getting a patch to apply to the
> RTEMS source base?
The attached mvme5500-patch.tar.gz contains two files :
mvme5500-rtems4.8.0-2009319.diff
mvme5500-rtems4.9.1-20090319.diff
I tried to file a PR, but it seems that there are some problems
with the bug tracking system : bugzilla. I could not even view
https://www.rtems.org/bugzilla/show_bug.cgi?id=1385
It was OK last week, though.
Kate
> --joel sherrill
> RTEMS
> Kate Feng wrote:
>> Hi,
>> The stable version of RTEMS-mvme5500 BSP is posted at
>> http://www.nsls.bnl.gov/facility/expsys/software/EPICS/
>> The "RTEMS-mvme5500 BSP v1.4.9.1", was tested
>> under RTEMS 4.9.1, and the "RTEMS-mvme5500 BSP v1.4.8.0"
>> was tested under RTEMS 4.8.0..
>> The highlights of the change are :
>> 1) Use the GT_GPP_Value register (0xf104) instead of the
>> GT_GPP_Interrupt_Cause register (0xf108) to monitor the cause
>> of the level sensitive interrupts. See irq/BSP_irq.c.
>> This is an unique solution which solves part of the bugs in
>> the BSP, which especially affects the 1GHz network driver.
>> 2) There is no change in the 100 MHz network driver. Thus,
>> its performance stays the same. Some bugs were fixed in the
>> 1GHz network drivers (e.g. if_wm.c).
>> 3)Enable "PCI Read Agressive Prefetch", "PCI Read Line Agressive
>> Prefetch",
>> and "PCI Read Multiple Agressive Prefetch" to improve the performance of
>> the PCI based applications (e.g. 1GHz network driver). See
>> pci/pci_interface.c.
>> However, performance is driven by applications.
>> There is no known bug at this point. Any feedback which is related to
>> the RTEMS-mvme5500 BSP would be highly appreciated.
>> Hope this helps,
>> Kate
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
More information about the rtems-users
