Debian-host build error...
Ed Sutter
esutter at alcatel-lucent.com
Wed Jun 24 15:05:57 CDT 2009
One more snippet of information...
I figured I'd test to see if the problem was blackfin-tools related, so
I installed the powerpc tools and got the exact same error...
els:powerpc-rtems4.10-gcc --help
powerpc-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4' not fou
nd (required by powerpc-rtems4.10-gcc)
Ed
Ed Sutter wrote:
> Daron & all,
> Yep, that was a typo. The PATH is correct; however, I hadnt' actually
> tried the cross-compiler out manually, and there is an issue...
> Forget about successful cross-compilation, there are shared libs it
> can't find...
> els:bfin-rtems4.10-gcc --help
> bfin-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4' not found
> (required by bfin-rtems4.10-gcc)
> A little googling seems to indicate that this is a strange issue with Debian
> because it happens with other tools. Haven't figured out how to get around it
> though.
> Ed
> Daron Chabot wrote:
>> Hi Ed,
>> Have not used alien to convert rpms to debs, but:
>> Have you verified that your cross-compiler works ? You should get an
>> "a.out" file from cross-compiling this:
>> int foo(void) { return 0; }
>> Also, I noticed you specified "export PATH=/opt/rtems-4.9/bin:$PATH"...
>> i assume the "rtems-4.9" was simply a typo, and your path actually
>> points to the correct tool versions...
>> -- dc
>> On Wed, Jun 24, 2009 at 12:46 PM, Ed Sutter <esutter at alcatel-lucent.com
>> <mailto:esutter at alcatel-lucent.com>> wrote:
>> Ian,
>> Thanks, here's more info...
>> I'm following the steps from the "Quick Start" wiki page.
>> First I got the prebuilt tools from:
>> http://www.rtems.org/ftp/pub/rtems/linux/4.10/fedora/10/i386/
>> I followed the Debian-specific instructions at:
>> http://www.rtems.com/wiki/index.php/RTEMS_Prebuilt_Tools
>> which talk about the "alien" tool and the conversion from .rpm to .deb.
>> All that appears to work just fine.
>> Then, referring to the "Example Application Compiling" page
>> I execute these steps...
>> cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login
>> cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P rtems
>> cd rtems
>> ./bootstrap
>> cd ..
>> mkdir bf537Stamp
>> cd bf537Stamp
>> ../rtems/configure --target=bfin-rtems4.10
>> --enable-rtemsbsp=bf537Stamp \
>> --enable-tests=samples --disable-posix --disable-itron
>> make all
>> The error occurs in the "make all" step. It apparently runs yet another
>> configure down below, and that's the point where it chokes. Attached
>> is the output of the "make all", as well as the config.log file that the
>> error in the make output is referring to.
>> Thanks for any help you can offer! I'm bracing myself for being told
>> I'm doing something really stupid. :-(
>> Ed
>> Ian Caddy wrote:
>> Hi Ed,
>> I am not really sure, but do you have any more details?
>> Such as when the error occurred, I assume during configure?
>> If so, did you look at the config.log output to see if it gave
>> any clues as to why it failed the check for being able to build
>> executables?
>> regards,
>> Ian Caddy
>> Ed Sutter wrote:
>> Folks,
>> Didn't get any responses on this, so I figured I'd try again...
>> When I reported this error, I was using pre-built tools from:
>> http://www.rtems.org/ftp/pub/rtems/linux/4.9/redhat/el5/i386/
>> then the other day I started over using:
>> The exact same error occurred, so I'm still clueless.
>> Even the "remotest" of suggestions at this point would not
>> be in vain
>> (yea, I'm begging) :-( otherwise, I suppose I have to hunt
>> down a different
>> Linux box (non-debian) to isolate this problem.
>> Thanks,
>> Ed
>> Ed Sutter wrote:
>> Folks,
>> I'm walking through the quick-start procedure for
>> building the
>> BF537Stamp BSP. My development host is Debian, and I've
>> gotten
>> to the point (on the quick-start page) where it mentions
>> the error:
>> * If you experience a "C compiler cannot create
>> executables" error,
>> * try fixing your compiler by getting libc-dev
>> I ran apt-get install libc-dev and got the following
>> message:
>> * root:apt-get install libc-dev
>> * Reading package lists... Done
>> * Building dependency tree... Done
>> * Note, selecting libc6-dev instead of libc-dev
>> * libc6-dev is already the newest version.
>> * 0 upgraded, 0 newly installed, 0 to remove and 1 not
>> upgraded.
>> Anyone working with a Debian host that has had (and
>> overcame) this
>> problem?
>> Thanks
>> Ed
>> rtems-users mailing list
>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>> http://www.rtems.org/mailman/listinfo/rtems-users
>> No virus found in this incoming message.
>> Checked by AVG - www.avg.com <http://www.avg.com> Version:
>> 8.5.375 / Virus Database: 270.12.90/2198 - Release Date:
>> 06/23/09 17:54:00
>> This file contains any messages produced by compilers while
>> running configure, to aid debugging if configure makes a mistake.
>> It was created by rtems-c configure 4.9.99.0, which was
>> generated by GNU Autoconf 2.63. Invocation command line was
>> $ ../../../rtems/c/configure --prefix=/opt/rtems-4.10
>> --host=bfin-rtems4.10 --build=i686-pc-linux-gnu
>> --target=bfin-rtems4.10 --enable-rtemsbsp=bf537Stamp
>> --with-target-subdir=bfin-rtems4.10
>> --exec-prefix=/opt/rtems-4.10/bfin-rtems4.10
>> --includedir=/opt/rtems-4.10/bfin-rtems4.10/include
>> --cache-file=/dev/null --srcdir=../../../rtems/c
>> ## Platform. ##
>> hostname = xpcelslinux1
>> uname -m = i686
>> uname -r = 2.6.18-6-486
>> uname -s = Linux
>> uname -v = #1 Mon May 4 23:59:22 UTC 2009
>> /usr/bin/uname -p = unknown
>> /bin/uname -X = unknown
>> /bin/arch = i686
>> /usr/bin/arch -k = unknown
>> /usr/convex/getsysinfo = unknown
>> /usr/bin/hostinfo = unknown
>> /bin/machine = unknown
>> /usr/bin/oslevel = unknown
>> /bin/universe = unknown
>> PATH: /home/els/bin
>> PATH: /usr/local/bin
>> PATH: /usr/bin
>> PATH: /bin
>> PATH: /usr/games
>> PATH: /home/els/bin
>> PATH: /sbin
>> PATH: /opt/uClinux/bfin-elf/bin
>> PATH: /opt/uClinux/bfin-uclinux/bin
>> PATH: /opt/uClinux/bfin-linux-uclibc/bin
>> PATH: /opt/arm-2007q3/bin
>> PATH: /opt/rtems-4.10/bin
>> ## Core tests. ##
>> configure:1821: checking for gmake
>> configure:1851: result: no
>> configure:1821: checking for make
>> configure:1837: found /usr/bin/make
>> configure:1848: result: make
>> configure:1873: checking for RTEMS Version
>> configure:1875: result: 4.9.99.0
>> configure:1885: checking build system type
>> configure:1903: result: i686-pc-linux-gnu
>> configure:1925: checking host system type
>> configure:1940: result: bfin-unknown-rtems4.10
>> configure:1963: checking target system type
>> configure:1978: result: bfin-unknown-rtems4.10
>> configure:2006: checking rtems target cpu
>> configure:2029: result: bfin
>> configure:2049: checking for a BSD-compatible install
>> configure:2117: result: /usr/bin/install -c
>> configure:2128: checking whether build environment is sane
>> configure:2171: result: yes
>> configure:2196: checking for a thread-safe mkdir -p
>> configure:2235: result: /bin/mkdir -p
>> configure:2248: checking for gawk
>> configure:2278: result: no
>> configure:2248: checking for mawk
>> configure:2264: found /usr/bin/mawk
>> configure:2275: result: mawk
>> configure:2286: checking whether make sets $(MAKE)
>> configure:2308: result: yes
>> configure:2379: checking for bfin-rtems4.10-strip
>> configure:2395: found /opt/rtems-4.10/bin/bfin-rtems4.10-strip
>> configure:2406: result: bfin-rtems4.10-strip
>> configure:2483: checking whether to enable maintainer-specific
>> portions of Makefiles
>> configure:2492: result: no
>> configure:2593: checking for bf537Stamp.cfg
>> configure:2607: result: ../../../rtems/c/../make/custom/bf537Stamp.cfg
>> configure:2899: creating ./config.status
>> ## Running config.status. ##
>> This file was extended by rtems-c config.status 4.9.99.0, which was
>> CONFIG_FILES =
>> CONFIG_HEADERS =
>> CONFIG_LINKS =
>> CONFIG_COMMANDS =
>> $ ./config.status
>> on xpcelslinux1
>> config.status:690: creating Makefile
>> ## Cache variables. ##
>> ac_cv_build=i686-pc-linux-gnu
>> ac_cv_env_build_alias_set=set
>> ac_cv_env_build_alias_value=i686-pc-linux-gnu
>> ac_cv_env_host_alias_set=set
>> ac_cv_env_host_alias_value=bfin-rtems4.10
>> ac_cv_env_target_alias_set=set
>> ac_cv_env_target_alias_value=bfin-rtems4.10
>> ac_cv_host=bfin-unknown-rtems4.10
>> ac_cv_path_install='/usr/bin/install -c'
>> ac_cv_path_mkdir=/bin/mkdir
>> ac_cv_prog_AWK=mawk
>> ac_cv_prog_MAKE=make
>> ac_cv_prog_STRIP=bfin-rtems4.10-strip
>> ac_cv_prog_make_make_set=yes
>> ac_cv_target=bfin-unknown-rtems4.10
>> ## Output variables. ##
>> ACLOCAL='${SHELL} /home/els/rtems/rtems/missing --run aclocal-1.10'
>> AMTAR='${SHELL} /home/els/rtems/rtems/missing --run tar'
>> AUTOCONF='${SHELL} /home/els/rtems/rtems/missing --run autoconf'
>> AUTOHEADER='${SHELL} /home/els/rtems/rtems/missing --run autoheader'
>> AUTOMAKE='${SHELL} /home/els/rtems/rtems/missing --run automake-1.10'
>> AWK='mawk'
>> CYGPATH_W='echo'
>> DEFS='-DPACKAGE_NAME=\"rtems-c\" -DPACKAGE_TARNAME=\"rtems-c\"
>> -DPACKAGE_VERSION=\"4.9.99.0\" -DPACKAGE_STRING=\"rtems-c\
>> 4.9.99.0\" -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\"'
>> ECHO_C=''
>> ECHO_N='-n'
>> ECHO_T=''
>> INSTALL_DATA='${INSTALL} -m 644'
>> INSTALL_PROGRAM='${INSTALL}'
>> INSTALL_SCRIPT='${INSTALL}'
>> INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
>> LIBOBJS=''
>> LIBS=''
>> LTLIBOBJS=''
>> MAINT='#'
>> MAINTAINER_MODE_FALSE=''
>> MAINTAINER_MODE_TRUE='#'
>> MAKE='make'
>> MAKEINFO='${SHELL} /home/els/rtems/rtems/missing --run makeinfo'
>> MKDIR_P='/bin/mkdir -p'
>> PACKAGE='rtems-c'
>> PACKAGE_BUGREPORT='http://www.rtems.org/bugzilla'
>> PACKAGE_NAME='rtems-c'
>> PACKAGE_STRING='rtems-c 4.9.99.0'
>> PACKAGE_TARNAME='rtems-c'
>> PACKAGE_VERSION='4.9.99.0'
>> PATH_SEPARATOR=':'
>> PROJECT_ROOT='../$(top_builddir)'
>> PROJECT_TOPdir='../../$(top_builddir)'
>> RTEMS_BSP_LIST=' bf537Stamp'
>> RTEMS_CPU='bfin'
>> RTEMS_TOPdir='..'
>> SET_MAKE=''
>> SHELL='/bin/sh'
>> STRIP='bfin-rtems4.10-strip'
>> VERSION='4.9.99.0'
>> am__isrc=' -I$(srcdir)'
>> am__leading_dot='.'
>> am__tar='${AMTAR} chof - "$$tardir"'
>> am__untar='${AMTAR} xf -'
>> bindir='${exec_prefix}/bin'
>> build='i686-pc-linux-gnu'
>> build_alias='i686-pc-linux-gnu'
>> build_cpu='i686'
>> build_os='linux-gnu'
>> build_vendor='pc'
>> datadir='${datarootdir}'
>> datarootdir='${prefix}/share'
>> docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
>> dvidir='${docdir}'
>> exec_prefix='/opt/rtems-4.10/bfin-rtems4.10'
>> host='bfin-unknown-rtems4.10'
>> host_alias='bfin-rtems4.10'
>> host_cpu='bfin'
>> host_os='rtems4.10'
>> host_vendor='unknown'
>> htmldir='${docdir}'
>> includedir='/opt/rtems-4.10/bfin-rtems4.10/include'
>> infodir='${datarootdir}/info'
>> install_sh='$(SHELL) /home/els/rtems/rtems/install-sh'
>> libdir='${exec_prefix}/lib'
>> libexecdir='${exec_prefix}/libexec'
>> localedir='${datarootdir}/locale'
>> localstatedir='${prefix}/var'
>> mandir='${datarootdir}/man'
>> mkdir_p='/bin/mkdir -p'
>> oldincludedir='/usr/include'
>> pdfdir='${docdir}'
>> prefix='/opt/rtems-4.10'
>> program_transform_name='s&^&bfin-rtems4.10-&'
>> psdir='${docdir}'
>> rtems_bsp_configure='../../../../rtems/c/src/configure
>> '\''--prefix=/opt/rtems-4.10'\'' '\''--host=bfin-rtems4.10'\''
>> '\''--build=i686-pc-linux-gnu'\'' '\''--target=bfin-rtems4.10'\''
>> '\''--enable-tests=samples'\'' '\''--disable-posix'\''
>> '\''--disable-itron'\'' '\''--with-target-subdir=bfin-rtems4.10'\''
>> '\''--exec-prefix=/opt/rtems-4.10/bfin-rtems4.10'\''
>> '\''--includedir=/opt/rtems-4.10/bfin-rtems4.10/include'\''
>> '\''build_alias=i686-pc-linux-gnu'\''
>> '\''host_alias=bfin-rtems4.10'\''
>> '\''target_alias=bfin-rtems4.10'\''
>> '\''--with-project-root=../../'\'' '\''--with-project-top=../../'\'''
>> sbindir='${exec_prefix}/sbin'
>> sharedstatedir='${prefix}/com'
>> sysconfdir='${prefix}/etc'
>> target='bfin-unknown-rtems4.10'
>> target_alias='bfin-rtems4.10'
>> target_cpu='bfin'
>> target_os='rtems4.10'
>> target_vendor='unknown'
>> ## confdefs.h. ##
>> #define PACKAGE_NAME "rtems-c"
>> #define PACKAGE_TARNAME "rtems-c"
>> #define PACKAGE_VERSION "4.9.99.0"
>> #define PACKAGE_STRING "rtems-c 4.9.99.0"
>> #define PACKAGE_BUGREPORT "http://www.rtems.org/bugzilla"
>> configure: exit 0
>> Making all in make
>> make[1]: Entering directory `/home/els/rtems/bf537Stamp/make'
>> make[1]: Nothing to be done for `all'.
>> make[1]: Leaving directory `/home/els/rtems/bf537Stamp/make'
>> Making all in tools/build
>> make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/build'
>> make all-am
>> make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/build'
>> gcc -DHAVE_CONFIG_H -I. -I../../../rtems/tools/build -g -O2 -MT
>> cklength.o -MD -MP -MF .deps/cklength.Tpo -c -o cklength.o
>> ../../../rtems/tools/build/cklength.c
>> mv -f .deps/cklength.Tpo .deps/cklength.Po
>> gcc -g -O2 -o cklength cklength.o
>> eolstrip.o -MD -MP -MF .deps/eolstrip.Tpo -c -o eolstrip.o
>> ../../../rtems/tools/build/eolstrip.c
>> mv -f .deps/eolstrip.Tpo .deps/eolstrip.Po
>> gcc -g -O2 -o eolstrip eolstrip.o
>> packhex.o -MD -MP -MF .deps/packhex.Tpo -c -o packhex.o
>> ../../../rtems/tools/build/packhex.c
>> mv -f .deps/packhex.Tpo .deps/packhex.Po
>> gcc -g -O2 -o packhex packhex.o
>> unhex.o -MD -MP -MF .deps/unhex.Tpo -c -o unhex.o
>> ../../../rtems/tools/build/unhex.c
>> mv -f .deps/unhex.Tpo .deps/unhex.Po
>> gcc -g -O2 -o unhex unhex.o
>> rtems-bin2c.o -MD -MP -MF .deps/rtems-bin2c.Tpo -c -o rtems-bin2c.o
>> ../../../rtems/tools/build/rtems-bin2c.c
>> mv -f .deps/rtems-bin2c.Tpo .deps/rtems-bin2c.Po
>> gcc -g -O2 -o rtems-bin2c rtems-bin2c.o
>> binpatch.o -MD -MP -MF .deps/binpatch.Tpo -c -o binpatch.o
>> ../../../rtems/tools/build/binpatch.c
>> mv -f .deps/binpatch.Tpo .deps/binpatch.Po
>> gcc -g -O2 -o binpatch binpatch.o
>> make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
>> make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
>> Making all in tools/cpu
>> make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
>> Making all in generic
>> `/home/els/rtems/bf537Stamp/tools/cpu/generic'
>> make[2]: Nothing to be done for `all'.
>> make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
>> make[2]: Nothing to be done for `all-am'.
>> make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
>> make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
>> Making all in testsuites/tools
>> `/home/els/rtems/bf537Stamp/testsuites/tools'
>> `/home/els/rtems/bf537Stamp/testsuites/tools/generic'
>> make[2]: Leaving directory `/home/els/rtems/bf537Stamp/testsuites/tools'
>> make[1]: Leaving directory `/home/els/rtems/bf537Stamp/testsuites/tools'
>> Making all in bfin-rtems4.10/c
>> `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>> Making all in .
>> Configuring RTEMS_BSP=bf537Stamp
>> checking for gmake... no
>> checking for make... make
>> checking build system type... i686-pc-linux-gnu
>> checking host system type... bfin-unknown-rtems4.10
>> checking rtems target cpu... bfin
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking whether build environment is sane... yes
>> checking for a thread-safe mkdir -p... /bin/mkdir -p
>> checking for gawk... no
>> checking for mawk... mawk
>> checking whether make sets $(MAKE)... yes
>> checking for bfin-rtems4.10-strip... bfin-rtems4.10-strip
>> checking whether to enable maintainer-specific portions of
>> Makefiles... no
>> checking for RTEMS_BSP... bf537Stamp
>> checking for
>> ../../../../rtems/c/src/../../bspkit/bfin/*/cfg/bf537Stamp.cfg... no
>> checking for
>> ../../../../rtems/c/src/../../make/custom/bf537Stamp.cfg... yes
>> checking whether BSP supports networking... yes
>> checking whether CPU supports libposix... disabled
>> configure: setting up make/custom
>> checking for
>> checking for
>> configure: creating make/bf537Stamp.cache
>> make[3]: Entering directory
>> `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp'
>> make[3]: Leaving directory
>> checking for RTEMS_CPU_MODEL... bf537
>> checking for RTEMS_BSP_FAMILY... (cached) bf537Stamp
>> checking for CPU_CFLAGS... (cached)
>> checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
>> checking for style of include used by make... GNU
>> checking for bfin-rtems4.10-gcc... bfin-rtems4.10-gcc
>> checking for bfin-rtems4.10-gcc... (cached) bfin-rtems4.10-gcc
>> checking for C compiler default output file name...
>> configure: error: in
>> `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp':
>> configure: error: C compiler cannot create executables
>> See `config.log' for more details.
>> make[2]: *** [bf537Stamp] Error 1
>> make[2]: Leaving directory `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>> make: *** [all-recursive] Error 1
More information about the rtems-users
