QEMU and RTEMS problem on Ubuntu
JiSheng Zhang
jszhang3 at gmail.com
Tue Jul 14 22:17:55 CDT 2009
OK I have send the floppy image to her
Any idea about how to make an grub2 floppy image?
Jisheng
2009/7/15 JiSheng Zhang <jszhang3 at gmail.com>:
> 2009/7/15 Chris Johns <chrisj at rtems.org>:
>> JiSheng Zhang wrote:
>>> IMHO, there's a lot of bugs in grub2 now. So it's better to use grub, it
>>> is OK
>> I build grub2 and use it without any problems on Fedora. The only issue I
>> have had is the ata.o module. Do not use this one.
>>> 2009/7/15 Roxana Leontie <roxana.leontie at gmail.com>:
>>>> Ralf the difference between Ubuntu and Fedora (grub2 vs grub[1]) is not
>>>> something that I have to worry about. I am using a rtems-boot.img from
>>>> Chris
>>>> Johns that has the grub version 1.96 on it and can read the ext2 file
>>>> system.
>>> I got the same results when using the img form Chris Johns
>> Interesting. I have not followed what host you are using. Is it Ubuntu ?
> I'm using debian unstable
>> Do you have a working grub image that Roxana can use ?
> I don't know how to make grub2 image(there's filesystem on it). I just
> make a grub floppy image which filesystem is ext2. But how can I send
> the image to Roxana? I have no pub ftp\http etc.
> If we don't need make filesystem on floppy image, there's no problem
> with grub2(just dd if=boot.img etc.)
>> Regards
>> Chris
> Thanks,
> Jisheng
More information about the rtems-users
