QEMU and RTEMS problem on Ubuntu
Chris Johns
chrisj at rtems.org
Tue Jul 14 19:08:56 CDT 2009
JiSheng Zhang wrote:
> IMHO, there's a lot of bugs in grub2 now. So it's better to use grub, it is OK
I build grub2 and use it without any problems on Fedora. The only issue I have
had is the ata.o module. Do not use this one.
> 2009/7/15 Roxana Leontie <roxana.leontie at gmail.com>:
>> Ralf the difference between Ubuntu and Fedora (grub2 vs grub[1]) is not
>> something that I have to worry about. I am using a rtems-boot.img from Chris
>> Johns that has the grub version 1.96 on it and can read the ext2 file
>> system.
> I got the same results when using the img form Chris Johns
Interesting. I have not followed what host you are using. Is it Ubuntu ?
Do you have a working grub image that Roxana can use ?
Regards
More information about the rtems-users
