Another Ethernet problem for Thomas :) Cont.
Leon Pollak
leonp at plris.com
Wed Jan 30 10:51:24 CST 2008
Thomas,
> > ************ INTERFACE STATISTICS ************
> > ***** eth0 *****
> > Ethernet Address: 00:80:7F:22:61:77
> > Address:192.168.50.133 Broadcast Address:192.168.50.255 Net
> > mask:255.255.255.0
> > Flags: Up Broadcast Running Simplex
> Back to the driver level: What would happen if your driver really works
> in simplex (half duplex) mode? If it sends a packet while receiving one,
> one of the two packets might get lost?
> I am not sure how you really set up the ethernet controller, so the
> flagged "simplex" might be misleading, but you should check it anyway.
> Thomas.
After searhes and scans: this is what all rtems drivers set in if->if_flags
after initializing. I put this too without thinking...:(
My driver is full duplex and works this way, so I removed this assignment. Now
the line shows : Up Broadcast Running
and no simplex. I tried to set IFF_DUPLEX
Tests showed no visible influence.
Thomas, Joel,
Please, don't you think that arp request to itself is weird?
Thanks.
Leon
More information about the rtems-users
