RTEMS on Nintendo DS port
Matthieu Bucchianeri
mbucchia at gmail.com
Mon Jan 28 18:20:43 CST 2008
On Jan 22, 2008 10:13 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Better (I think): Add a constant unsigned integer variable to the BSP
> which is set to the value of the system/supv mode you need to be in
> and let the _CPU_Context_Initialize body extern that and use it.
> Every BSP will have to provide one but this isn't a hard change.
> Define the variable in extern arm bspstart.c and set it to the
> default. Use a different value in gba and ds.
Sorry for the delay Joel, I did not thank you for your answer :-)
I think this solution will work fine.
> > Thank you, our patch we be ready very soon :-)
> I can't wait. Hopefully we can figure out what to do
> about the libnds.
For the moment, I cannot work on it as I am preparing to move for my
end-of-studies internship.
I will be working again on the patch in 2-3 weeks, sorry for the
delay, I will be doing my best :-)
Matthieu
More information about the rtems-users
