AIO support for rtems; telnet and console IO
CWolfe at motioncontrol.org
Tue Jan 15 11:07:33 CST 2008
I'm writing an rtems application which needs to communicate via telnet and I have
some questions. my original plan was to intercept all console io on the serial ports and pass
to/from the socket. I tried to use send() and recv() with MSG_DONTWAIT enabled, but this
generates an error message stating no processes available. my next attempt tried to use
aio_read and aio_write, but --after much hairpulling-- i read the documentation to discover
that this feature is not currently supported. My questions are these:
1.) is there a better approach which emulates an interrupt-driven console io scheme
(prehaps using posix signals, callbacks and socket io)
2.) aio seems to be a handy library to have, so I might be interested in writing the
code. has anyone done this yet? if not, where would i find enough information to
complete the existing code? (i.e. posix specs etc.)
3.) is there define(perhaps one i should have made) which would prevent the no
processes available error message?
4.) it seems that some of the bsd code is a bit sliced using the __BSD_VISIBLE
#define. what exactly is the purpose of this define, and is it advisable to
undef/redefine to enable the macros which allow non-blocking socket io?
5.) if all else fails, I could rewrite our code to use a tty terminal in lieu of intercepting
the serial IO, but i am not sure how to read and write to a tty terminal. is there a
good example available which demonstrates it's usage in an rtems app?
Regards,
Christopher Wolfe
Motion Control Systems, Inc.
# using rtems4.7.1/mcf5235
More information about the rtems-users
