gdb macros fails
Tim Cussins
timcussins at eml.cc
Thu Oct 18 08:04:13 CDT 2007
Hi Leon
IIRC in rtems 4.6, front_flag is a member of struct Heap_Block_struct
which is defined in "cpukit/score/include/rtems/score/heap.h"
As I undrstand it, the heap manager has undergone a few changes, and
this member has been renamed. I'll leave it to the experts
to tell you if it's usage has changed also (the LSB has special meaning
in rtems 4.6).
This should get you started.
Cheers,
Tim
On Thu, 18 Oct 2007 14:49:26 +0200, "Leon Pollak" <leonp at plris.com>
said:
> Hello, all.
> I tried to use for the first time the gdb macros rtems_heap_walk and
> rtems_workspace_walk.
> Both failed saying:
> There is no member named front_flag.
> I shall be very thankful for clarification where this flag may be (the
> macros
> file has the last change dated 7Aug2006, rtems is 4.7).
> Many thanks ahead.
> Leon
> rtems-users mailing list
> rtems-users at rtems.com
More information about the rtems-users
