http network example
Arquer Stephane
stephane.arquer at c-s.cnes.fr
Thu Oct 18 07:31:41 CDT 2007
Hello,
I configured my 3c905 nic with elnk driver from th Rtems version 4.6.6
with the http example. It's working correctly.
I installed Rtems 4.7.1 and the http execution is frozen after the
message: "etherlink: unit elnk1 driver attached".
My configure parameters are :
#define TEST_INIT
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
#define CONFIGURE_EXECUTIVE_RAM_SIZE (512*1024)
#define CONFIGURE_MAXIMUM_SEMAPHORES 20
#define CONFIGURE_MAXIMUM_TASKS 20
#define CONFIGURE_MAXIMUM_TIMERS 5
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 5
#define CONFIGURE_MICROSECONDS_PER_TICK 10000
#define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
#define CONFIGURE_INIT_TASK_PRIORITY 120
#define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
RTEMS_NO_TIMESLICE | \
RTEMS_NO_ASR | \
RTEMS_INTERRUPT_LEVEL(0))
Is there something else to add for this version ?
Stephane.
More information about the rtems-users
