firewire video on RTEMS-4.6.x-MVME5500
Kate Feng feng1 at bnl.gov
Wed Oct 10 12:42:40 CDT 2007
Mark Rivers wrote:
> I recently got a GigE camera from Prosilica.  It is 1360x1024
> resolution.  At 8-bits the StreamPix software from Norpix is able to
> acheive frame rates of 30Hz at full resolution, and 52 Hz when it is
> 2x2 binned to 680x512.  This is under Windows, using the single GigE
> port on the PC, with the camera and PC connected directly to a GigE
> switch (which also is connected to the rest of the LAN).
Does the window has any tool to measure the actual
network throughput of the  1GHz ?  Or do you have any
H/W tool to measure it ?  If so, how many Mega bytes/sec
of throughput ?
Can the window run remote client ?
Regards,
Kate
> Mark
>     *From:* tech-talk-bounces at aps.anl.gov
>     [mailto:tech-talk-bounces at aps.anl.gov] *On Behalf Of *Kate Feng
>     *Sent:* Wednesday, October 10, 2007 10:17 AM
>     *To:* Daron Chabot; rtems-users at rtems.org; tech-talk at aps.anl.gov
>     *Subject:* Re: firewire video on RTEMS-4.6.x-MVME5500
>     Daron Chabot wrote:
>>     Sorry for not being more clear: I am only interested in the EPICS
>>     and EDM applications you've created for displaying the video, not
>>     in any of the RTEMS-related code.
>     I did not change any EDM applications or EPICS base.  The protocol
>     is CA.   The optimization is implemented at RTEMS device driver
>     and IIDC1394 library layers. The BSP is RTEMS-MVME5500.
>     The driver does not have to be linked to EPICS.
>     It is just another real-time application with the RTEMS-MVME5500
>     BSP.  It triggers the camera at 30 fps and  display at 30Hz
>     simultaneously for the 1024x768x8bit mode (video mode) even under the
>     limited 100MHz network bandwidth and indeterministic network
>     environment.
>     Yes,  in the 100MHz NIC, the actual network throughput is not
>     30Hzx1024x768x8 bits. But it is greater than 10Hz.  Thus, the
>     system does
>     not have to run in a private network. I do not believe it
>     will  be slower with a non-EPICS application.
>>     Here at the CLS we're using linux-based soft IOCs to communicate
>>     with Flea and Flea2 cameras.
>>     We're having difficulty in achieving video frame rates greater
>>     than about 10 Hz at 640x480 resolution. I'm interested to know
>>     how you are getting such fine performance (aside from using RTEMS
>     Perhaps I will have the optimization written in a publication, so that
>     hopefully it can help the Linux or vxWorks users.  If so,  will you
>     feedback to this list regarding how much improvement you achieved
>     in the Linux driver ?
>     Regards,
>     Kate
URL: <http://www.rtems.org/pipermail/rtems-users/attachments/20071010/68d7f9fc/attachment.html>
More information about the rtems-users mailing list
