question about thread on rtems for pc386's context
xi yang
hiyangxi at gmail.com
Mon Oct 8 23:31:35 CDT 2007
Yu chen:
These Contex_Control registers are callee saved registers.
It's used to avoid unnecessary saving register if there is on
context switch after this ISR. The first job of instructions of ISR
is to save caller saved registers-->These exceptions frame
(CPU_Exception_Frame)+
context_control is the whole registers .
Look at the comments of cpu.h of ARM.
2007/10/8, Yu Chen <chyyuu at gmail.com>:
> hi,
> From the source code, in Thread_Control_struct, the field
> 'Context_Control Registers' means the context of
> this thread. This field is hardware related. in RTEMS for pc 386, I
> found the define of this field is:
> typedef struct {
> uint32_t eflags; /* extended flags register */
> void *esp; /* extended stack pointer register */
> void *ebp; /* extended base pointer register */
> uint32_t ebx; /* extended bx register */
> uint32_t esi; /* extended source index register */
> uint32_t edi; /* extended destination index flags register */
> } Context_Control;
> My question is: why rtems didn't store the other i386 registers (such
> as eax, ecx...) when switching the thread context? the other registers
> in threads needn't save &restore?
> and the similar question is: in irq_asm.S , rtems_irq_prologue_ ## _vector :
> SYM (rtems_irq_prologue_ ## _vector ): \
> pushl eax ; \
> pushl ecx ; \
> pushl edx ; \
> movl $ _vector, ecx ; \
> jmp SYM (_ISR_Handler) ;
> popl edx
> popl ecx
> popl eax
> iret
> why in irq process, rtems didn't save &restore the other i386 registers ?
> Thanks!
> Best Regards
> Chen Yu
> Laboratory of Pervasive Computing,
> Dept. of Computer Science and Technology
> Tsinghua University, Beijing 100084, P.R. China
> E-Mail: mailto:yuchen at tsinghua.edu.cn chyyuu at gmail.com
> rtems-users mailing list
> rtems-users at rtems.com
More information about the rtems-users
