MCF5329EVB BSP
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Oct 5 16:07:47 CDT 2007
Kirspel, Kevin wrote:
> There are no licensing issues with the BSP. The port does require a change
> to the gnu tool chain generation so that it generates a m68k-rtems for the
> coldfire version 3 core (m5307 cpu).
OK. That's another kettle of fish entirely. Eventually gcc will catch
up. :D
--joel
> Kevin Kirspel
> Opti Medical Systems
> Electrical Engineer
> 235 Hembree Park Drive
> Roswell GA 30076
> (ph) 770-510-4444 x4568
> (fax) 770-510-4445
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Friday, October 05, 2007 2:36 PM
> To: Kirspel, Kevin
> Cc: 'rtems-users at rtems.org'
> Subject: Re: MCF5329EVB BSP
>> I have almost completed a port to RTEMS of the MCF5329EVB evaluation
>> board from Freescale. With this BSP I had to port the YAFFS2 file
>> system to RTEMS. I would like to submit the BSP and YAFFS2 port to
>> RTEMS. The YAFFS2 license is GPL. I don't know if that is OK with
>> RTEMS. I would like to do some robustness testing on the YAFFS2 port.
>> Does RTEMS have a test plan/procedure to validate new file systems?
> Congratulations on the BSP and port. Is the license OK on the BSP? Other
> email
> deals with the YAFFS2 license issue.
> There are POSIX tests which exercise files through the C library IO
> calls and
> should exercise all the functionality available through "normal" APIs. You
> would just have to arrange to have that mounted and the paths point to it.
> --joel
>> Kevin Kirspel
>> Electrical Engineer
>> Roswell GA 30076
>> (fax) 770-510-4445
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
More information about the rtems-users
