MCF5329EVB BSP
Till Straumann
strauman at slac.stanford.edu
Fri Oct 5 15:42:45 CDT 2007
Joel Sherrill wrote:
> Till Straumann wrote:
>> Just a reminder that the filesystem framework currently is not
>> thread-safe!
> Your outstanding patches are in the queue for 4.9.
IIRC my patches don't cover making the FS framework thread-safe.
T
> --joel
>> T.
>>> Kirspel, Kevin wrote:
>>>> I have almost completed a port to RTEMS of the MCF5329EVB
>>>> evaluation board from Freescale. With this BSP I had to port the
>>>> YAFFS2 file system to RTEMS. I would like to submit the BSP and
>>>> YAFFS2 port to RTEMS. The YAFFS2 license is GPL. I don’t know if
>>>> that is OK with RTEMS. I would like to do some robustness testing
>>>> on the YAFFS2 port. Does RTEMS have a test plan/procedure to
>>>> validate new file systems?
>>> Congratulations on the BSP and port. Is the license OK on the BSP?
>>> Other email
>>> deals with the YAFFS2 license issue.
>>> There are POSIX tests which exercise files through the C library IO
>>> calls and
>>> should exercise all the functionality available through "normal"
>>> APIs. You
>>> would just have to arrange to have that mounted and the paths point
>>> to it.
>>> --joel
>>>> Kevin Kirspel
>>>> Opti Medical Systems
>>>> Electrical Engineer
>>>> 235 Hembree Park Drive
>>>> Roswell GA 30076
>>>> (ph) 770-510-4444 x4568
>>>> (fax) 770-510-4445
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
More information about the rtems-users
